mk1 and mk1.5 focus head lights
Can you fit mk1.5 (51reg upwards)to mk1 focus,es.I take it they will bolt straight in but how do you wire them up.
You can fit them (Not sure if it's a straight swap) but obviously you need to do wiring mods as you say, as the indicators are in the light clusters, sure there is info on here, have you done a search?
Martin
Martin
No i havent done a search i would just blank off the indicators.I would wire earths to the headlight and main beam bilbs then take a live off the old headlight plug and do it that way.
Oct 9, 2015 07:38 PM
saph in dorset
Aug 14, 2015 10:10 AM
