waterpump goosed on st170
Old Dec 25, 2011 | 04:00 PM
seddo's Avatar
seddo
Default waterpump goosed on st170
hi guys was driving car yesterday an noticed had a water leak so gave car a check an noticed me waterpump has gave up it looks. its look like the pulley has twisted an fanbelt is nearly coming off an it makes a horible noise when idling as if the propellors are hitting an area inside. my question is when i replace it is it an easy job to tackle with the right tools? im replacing fanbelt same time an wondering if can be done weithout taking the mechanics. also my fans are constantly running even when i had full water in the system. they wasnt spinning very fast but on a slower spin. air con was off to. any reason why they wud just spin at a slow rate if anybody had this problem before? thanks for help guys
jay
Old Dec 26, 2011 | 02:01 PM
seddo's Avatar
seddo
anybody??
anybody know if the 3 bolts have to come off the pulley wheel to rmemove the waterpump housing?
Old Dec 31, 2011 | 08:12 AM
Sp3no's Avatar
Sp3no
Yes otherwise you won't be able to access the pump housing bolts. the pump sits behind the cam belt but you can tease it out without removing the cam belt.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
