Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Atlas length
Old Dec 22, 2011 | 06:37 PM
bly's Avatar
bly
Default Atlas length
anyone know what a 50'' atlas axle is out of ??
what is mk2 Rs 2000 atlas 48'' ?
Old Dec 22, 2011 | 07:01 PM
29A's Avatar
29A
Where are you measuring to get 50"
I am using an Atlas from a 1.1 mk2 Escort (fitted to most european escorts), but they measure the standard 53" to the outside of the drums. Capris are 57". Didn't know there was a 50"??
Old Dec 22, 2011 | 07:05 PM
bly's Avatar
bly
from bearing face's on axle is 50'' and 54'' from halfshaft faces
Old Dec 22, 2011 | 07:14 PM
Retro Al's Avatar
Retro Al
RWD IS KING
That wont be a atlas, you will have koln
Old Dec 22, 2011 | 07:16 PM
bly's Avatar
bly
whats that out of
Old Dec 22, 2011 | 07:20 PM
Retro Al's Avatar
Retro Al
RWD IS KING
They are very weak, even weaker than a english axle they were fitted to european cars
Old Dec 22, 2011 | 07:22 PM
29A's Avatar
29A
Then it sounds like a european mk2 escort, the same as mine, they measure about 53 1/2". Ratios are usually 3.89:1. Mine is 4.11:1!! Or could be from a mk 1 capri.
Getting rare now, and known more as the baby atlas, a lot of people think these only came from mk1 capris, but they did live in escorts too.
Retro Al's Avatar
Retro Al
RWD IS KING
You need a atlas from a capri,i think mk1 capris had 50inch atlas, and the 2.8 had the full 54 inch
Old Dec 22, 2011 | 07:23 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Put a picture up will soon see if its a atlas
Old Dec 22, 2011 | 07:24 PM
29A's Avatar
29A
Every person I talk to has a different opinion of this. If it is a fact, which bit fails? I ran a 5.0L mustang engine through one of these in mk1 cortina and didn't break it, and I am now fitting one to a zetec turbo'd model 'A' truck I'm building, so fingers crossed
Old Dec 22, 2011 | 07:25 PM
bly's Avatar
bly
so no good for 300bhp then
Old Dec 22, 2011 | 07:28 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Get a picture up,if its a atlas it will be fine with 300bhp,if its a koln just do a google search theres plently of info about them
Old Dec 22, 2011 | 07:55 PM
bly's Avatar
bly
from what i found so far Narrow Atlas (Mk1 3 litre Capri) .. 50" long
and the koln axle is 48.5''
Old Dec 22, 2011 | 08:08 PM
bly's Avatar
bly
also has tag on diff that says 3.09 that is 3 litre Capri gearing?
Old Dec 22, 2011 | 08:39 PM
29A's Avatar
29A
Yes that'll be a mk1 baby 3.0L axle
Old Dec 22, 2011 | 08:42 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Does it look like this ? http://www.turbosport.co.uk/showthre...highlight=koln
The atlas has more uniform bolts so you can easily tell them apart
TommyB's Avatar
TommyB
Boosted 122 cu in
Baby atlas, almost a rear loading English axel?
Old Dec 22, 2011 | 08:46 PM
bly's Avatar
bly
not member so can not see that ,but bolts are all even round diff plate
Old Dec 22, 2011 | 10:08 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Its a atlas then
Old Dec 22, 2011 | 10:10 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Become a member,its the best forum for this kind of thing
Old Dec 23, 2011 | 06:45 PM
bly's Avatar
bly
stripped the axle today its got 3.09 marked on crown wheel and and 16spline halfshafts looks in good condition everythings cool thanks for your help
Old Dec 23, 2011 | 07:52 PM
Retro Al's Avatar
Retro Al
RWD IS KING
If you want any work done on it i recomend tom @ http://www.fostek.co.uk/
155lee
Sep 6, 2016 11:10 AM
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
A.t.p
Sep 29, 2015 05:04 PM
markk
18
Aug 17, 2015 05:19 AM
