Ford Puma Discuss the Ford Puma here!
Crap Puma headlights?!?!?!?!
Old Dec 21, 2011 | 08:30 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Crap Puma headlights?!?!?!?!
Anyone else have a puma and think that the headlights on dip are utter shit?
well i do, and having just spent some £32 on a pair of osram nightbreaker plus bulbs, its made very little difference other than the light being a bit whiter...
but they are still shit.
so i have taken to driving in the dark with full beam on and set the auto headlight adjuster to 5 to not blind oncoming traffic.
is there anything that can be done?? doing my head in now. gave a guy at work a lift home today and he recons his Clio 182 lights on dip are as bright as mine on full beam
Old Dec 21, 2011 | 08:36 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
its the glass domes that have deteriorated mate, only option is replace with new, then again at about £300 a side, maby not lol
Audi, bmw etc etc etc all suffer with this also, thats why so many people fit gash HID kits, but as of next year cars will not pass MOT unless they have automatic adjusters fitted to suspension to keep headlight aim "level"
Old Dec 21, 2011 | 08:41 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
fuck that, full beams it is
is there nothing that can be done to remove and clean the lens' up?
Old Dec 21, 2011 | 08:48 PM
Cossie Sean
well provided the lens isnt yellow, its the glass projector dome fella.
you could use some slightly illigal 100w bulbs or summat instead of HID`s,
My 1999 A4 lights are truely shocking, 100w bulbs made it better (but not 100%)
i tried untold ammounts of stuipid aftermarket, xennon, night breaker, day glow neon dildo glow in the dark stylee bulbs, made fuck all difference.
Old Dec 21, 2011 | 08:55 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
pmsl cheers mate. ill see what happens
Old Dec 21, 2011 | 08:57 PM
COCHYN's Avatar
COCHYN
F*ck spending mate, do what I did to pass the last MOT, use Autosol and a buffer or dremel. Brought the plastic lenses back to life within 10 mins and made them shine out like new
Old Dec 21, 2011 | 09:08 PM
Cossie Sean
its not shitty lense syndrome that foci suffer from mate
Old Dec 21, 2011 | 09:15 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
as sean said the actual plastic bits are fine. and it pissed through the mot with no issues not long ago. but night driving is an issue lol
Old Dec 21, 2011 | 09:31 PM
COCHYN's Avatar
COCHYN
No difference pal, the puma is actually worse with it than the Focus due to the angle it sits, suceptive to serious abuse over time. Mine are/were on the Puma
Old Dec 21, 2011 | 09:48 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
strip the light units down and give both the outer plastic lense a good clean and the glass projectors a clean and polish.
Youll be surprised how much crap builds up inside the so called "sealed" units......
Old Dec 21, 2011 | 10:09 PM
Cossie Sean
youve lost me............. :S
no idea what thats ment to say lol
Warren, probebly right although ive never tried it, only replaced on punters motors.
i thaught the glass deteriorated internaly on the domes, will try this on the A4
Old Dec 21, 2011 | 10:42 PM
Psycho Warren
Carbon Crazy
it depends what crap its had on it. I know people whove had good results cleaning the units up. Ultimately even with new headlights they arent the best as they are a very early basic projector design and stuff has moved on a lot since they were designed.
Im surprised no ones tried fitting units from a later ford.
Old Dec 22, 2011 | 07:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how do they come apart, mallet???
might have a look tomoz if i get chance at work lol
Old Dec 22, 2011 | 08:41 PM
Etty's Avatar
Etty
i took mine apart and cleaned them, didnt make much difference. i bought some bulbs from halfords, i think the extreme range. made driving at night possible. only cost £20. best mod for a puma.
Old Dec 22, 2011 | 08:49 PM
Dlatch!'s Avatar
Dlatch!
what about junking the original projectors and fitting some new ones?
http://furoreproducts.co.uk/6-projector-headlights
not had a puma light assembly apart though so can't say how easy it will be but it must be possible
Old Dec 22, 2011 | 09:16 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
If it's anything like Mondeo units the lens is glued to the plastic surround. There are some clips that you prise off, then with a big screwdriver carefully lever the two halves apart. With a very sharp blade cut the adhesive as you go and you can gradually pull them apart.
It's easier if the units are warm (leave them over a radiator for an hour or so) as it softens the glue.
Even if you do clean them, and fit groovy bulbs the light is never going to be amazing as they're a bit of a shit design, and even from new they were rubbish headlights.
Cochyn - How badly scuffed were your lights? One of mine (that I got from a breaker) has obviously been stored face down, and is noticeable scuffed. I assumed Autosol, or similar would just make them even more scuffed?
Old Dec 22, 2011 | 10:56 PM
stuboy's Avatar
stuboy
dunno any help to ur cause but woman guard i work with she borrowed her mum neon and headlights were yellow like the old french ones so i got a 4 quid tube of cutting compound and buffed em up, the end result was defiently better at night.
Old Dec 22, 2011 | 11:48 PM
Cossie Sean
its not the plastic outer lens that fails its the inner glass domes.
the like provided above could be good replacment if its a puma specific fittment
if not then dimensions MUST be bang on spec otherwise its as much use as a 13yr old with his first porn mag claiming to give long distance endurance
Old Dec 23, 2011 | 12:21 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well, i didnt touch the car this morning as its pissing down
ive just been driving witht he full beam on and the headlights adjusted down. no one has flashed me yet.
Old Dec 24, 2011 | 02:35 PM
COCHYN's Avatar
COCHYN
Regardless of the bulbs you use, you're not going to get the full advantage of any unless the plastic lenses are as clear as they can be. So the Puma's front end sits at an agle that picks up all kinds of debris from the road and other cars, so decided to take mine off the runaround Puma and Autosol'd them. Amazing result, and mine were quite bad after 200k miles on an R reg
Old Dec 24, 2011 | 06:00 PM
mjonathan24's Avatar
mjonathan24
Sand the lenses and then polish them... look at detailing world if you need pointers.
Old Dec 24, 2011 | 08:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
with lenses do you mean the actual outer plastic bit of the lamp, or the glass inner bit that the bulb shines through?
as i would personally call the lens the glass bit.
Old Dec 25, 2011 | 06:33 AM
Psycho Warren
Carbon Crazy
both probably full of dirt by now
Old Dec 25, 2011 | 11:45 AM
COCHYN's Avatar
COCHYN
The outter plastic mate, where all the abuse happens
Really, try it, you'll see a world of difference.
Old Dec 26, 2011 | 11:48 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
i dont have a buffer lol. ill see if i can get hold of one.
but right now the missus and i have some kind of bug and feel fooking aweful
merry fucking xmas
Old Dec 26, 2011 | 03:08 PM
Robs Frst's Avatar
Robs Frst
I had this issue on my Puma used this, it worked was impressed.
http://www.meguiars.co.uk/product/39...storation-Kit/
Old Dec 26, 2011 | 03:30 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cool, cheers mate, ive got meg scratch x that ill go with first by hand and see what happens.
Old Nov 7, 2012 | 08:53 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i got round to buying some autosol the other week and had a spare 10 mins at lunchtime today...
gave it a bit of a going over by hand and it done fuck all lol.... then i rememberd this thread, and cochyn said to use a drill and buffer.... i dont got me one of those
will see at the weekend lol
Old Nov 10, 2012 | 12:01 PM
AlexF's Avatar
AlexF
Just serached out this thread Dan...
I'm getting bored of mine this year and was considering bulbs vs HID...
Old Nov 10, 2012 | 09:11 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i really dont want to spend anything on it tho as im looking to chop it in as soon as i can for something with 4 doors and a boot lol
went to b&q earlier and couldnt find a drill buffer attachemnt thingy...
Old Jul 19, 2014 | 06:35 AM
trishaxuk's Avatar
trishaxuk
Lightbulb
I'm surprised nobody mentioned the adjusters. I just bought a (2000) Millennium edition, and thought I'd search on the topic. I used to have a black 2000 edition 1.7 a few years back. I had similar issues, and was using the high beam on low angle for a while, until I realised a way round it. The headlight projector/bulb assemblies (clusters) all have individual trimmer adjustments in the cluster, for each beam.
Look from the top, and you can see holes with a symbol. On the standard beam; I found I needed to raise them by a few turns (I think about 5-6 half turns). Makes a world of difference. In those days I had some slightly whiter 5W higher rated bulbs. Used the yellowish rain cutters for the fogs.
This time round, I think I'll do the HID upgrade as well, on the standard beams. I've heard from a few MOT testers, that with original projector assemblies; as long as the light pattern is still basically ok (usually the case with projectors because less affected by light source changes in comparison to a standard bulb in a parabolic dish configuration), they would not really be aware that the light is now HID. It would be tested as a standard headlight, and therefore will pass - but make sure if fitting them, that the light pattern thrown is basically correct and not insanely powerful HIDs, or you will obviously be dazzling others!
Old Jul 19, 2014 | 04:05 PM
STeve's Avatar
Super Moderator
old thread trish but I am sure some are still glad of your input
Old Aug 1, 2014 | 02:59 AM
trishaxuk's Avatar
trishaxuk
I did notice it was a bit old; but the Puma lives on, and is still a loved car. I only bought it because it was cheap, and I knew how amazing they were from when I had one before. I've been using my new acquisition as my primary car - and gotta say, loving it every bit as much as my original one. Still got the TT for projects and weekends, but so many cheap, and easy upgrades on the Puma.
I was going to HID the lights, but have actually held off on that as direct replacement LEDs have finally reached the consumer accessible market i.e. Amazon and eBay (very excited!!). I've already changed over most of the rear clusters, and waiting for the front replacements and click adjusting resisters for the indicators to arrive in the post. I'll update the thread when I see the outcome; but I remember dreaming about this possibility all those years ago, but thinking I'll need to buy an R8 or some modern Japanese born coupé to get my hands on them - loves my LEDs! lol
Old Aug 1, 2014 | 08:28 AM
Dal_'s Avatar
Dal_
Best way is to rub down the outer plastic with increasing grades of wet and dry. I did it recently...
Tickled with the front lights today:
Was full of little scratches and pits from 13 years on the road:
After some 400, 800, 2000 grit rubbing, compounding and polishing its not perfect, but much better:
Rough:
Mid - lubed up:
Finished:
You can see from the before and after light pattern on the outer plastic that more light is going through rather than being scattered by the pits.
Then fit some decent bulbs such as Halfords Extreme brilliance etc (when on BOGOF) and that'll be about as good as you can get it.
Old Apr 3, 2016 | 08:30 PM
moondustka's Avatar
moondustka
Boooost!
Reckon these will sort the problem, but majorly expensive at the moment!
http://www.horizonleds.co.uk/exterio...en-4000-lumens
Old Dec 14, 2016 | 08:07 PM
XR2DylanPop's Avatar
XR2DylanPop
Ford Nut
The first thing I noticed and liked about my Puma was the lights - I love them, never had projectors before and mine are white and clear, if I have them on in low daylight they look holographic on the vehicle in front too
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
youngben
Sep 27, 2015 09:37 PM
