My 400bhp 3dr Cosworth
Old Apr 14, 2004 | 12:19 PM
Ian3dr's Avatar
Ian3dr
Default My 400bhp 3dr Cosworth
Some recent pics took today. Hope you like.......
SPEC SHEET
ENGINE
200 COSWORTH BLOCK
STANDARD STEEL CRANK, STANDARD STEEL CON RODS
GENUINE COSWORTH PISTONS
LOW COMPRESSION (7.6:1)
HIGH PRESSURE OIL PUMP
BIG WINGED SUMP (extra 2 litres)
WRC METAL 4 LAYER HEAD GASKET
LONG STUDDED
4X4 POLISHED & PORTED HEAD
HARVEY GIBBS CAMS
KENT ADJUSTABLE VERNIERS
4X4 MANIFOLD
GT28 ROLLER BEARING TURBO WITH MODIFIED T34 FRONT HOUSING
GARRETT –31 ACTUATOR
GROUP A CAM BELT
GROUP A COIL
GENUINE RS500 INTERCOOLER WITH MODIFIED T34 FITTINGS
PACE RS500 FAST ROAD RADIATOR (50mm core)
PACE TURBO COOLER
BAILEY MOTORSPORT TURBO OIL FEED & PRE FILTER
SPEC-R GROUP A BREATHER/SEPARATOR SYSTEM
SPEC-R SWIRL POT
SPEC-R WATER COOLED POWER STEERING TANK
SPEC-R HEADER TANK (with sight glass)
STANT 21-25psi RADIATOR CAP WITH LEVER RELEASE
SAMCO BOOST & WATER HOSES
MIKALOR STAINLESS STEEL HOSE CLAMPS
MONGOOSE 3in STAINLESS STEEL EXHAUST (4 in tailpipe)
(with Powerflex hangers)
K&N CONE FILTER
WEBBER MARELLI LEVEL 8 ECU WITH PECTAL BABY BOARD
PECTAL 12 POSITION BOOST CONTROL (in car)
4 X 403 ‘GREY’ INJECTORS
WRC AIR INJECTORS
WATER INJECTION
044 FUEL PUMP
3 BAR MAP SENSOR
MOTORCRAFT AGP 701 SPARK PLUGS
FORD MOTORSPORT IGNITION LEADS
CASTROL RS 10w60 FULLY SYNTHETIC OIL
TRANSMISSION
STANDARD BORG WARNER T5 WITH QUICKSHIFT & LSD
LIGHTENED & BALANCED FLY WHEEL
ALCON 6 PADDLE, STANDARD FORD COVER
RECONDITIONED PROPSHAFT WITH UPRATED UJ’S
QUAIFE ATB 7 ˝ INCH DIFF, 3.65 FINAL DRIVE (standard)
POWER
405 bhp @ 6030 rpm
397 lbft TORQUE @ 4020 rpm
REV LIMITER 7100 rpm
PEAKS AT 32 psi, HOLDS 28psi
BUILT & TUNED BY HARVEY GIBBS
SCS, PETERBOROUGH. 01733 576614
MAPPED BY AHMED BAYJOO ON DYNO & IN CAR
BRAKES
FRONT: AP RACING CP5555 6 POT CALIPERS
330mm x 28mm DISCS & BELLS
FERRADO DS2500 PADS
REAR: 4x4 CALIPERS
300mm x 22mm DISCS & BELLS
FERRADO PADS
GOODRIDGE BRAIDED HOSES ALL ROUND
SUSPENSION
FRONT: KONI TOP ADJUSTABLE DAMPERS
EIBACH SPRINGS –20mm
POWERFLEX BUSHES
SPEC-R TWIN BAR STRUT BRACE (chromed)
REAR: KONI BOTTOM ADJUSTABLE DAMPERS
AVO STANDARD HEIGHT SPRINGS, 30% UPRATED
FORD BUSHES
REAR SHIM KIT
SPEC-R REAR STRUT BRACE
INTERIOR
STANDARD RECARO INTERIOR
RS MOTORSPORT 3 SPOKE STEERING WHEEL
WILLINS 4 POINT HARNESSES
DEFI OIL PRESSURE & TEMPERATURE AND EXHAUST GAS TEMPERATURE
DEFI CONTROLLER (with record and playback)
APEXI 2.5 BAR BOOST GUAGE (with record and playback)
S.E.C.S MONITER
SPEC-R WATER INJECTION TANK IN BOOT
FIRE EXTINGUISHER
EXTERIOR
FRONT WHEELS : COMPOMOTIVE MO, 7 I/2in x 17in ET 37
GOODYEAR EAGLE F1’s 215/40
REAR WHEELS : COMPOMOTIVE MO, 8in x 17in ET 35
GENUINE RS500 FRONT SPLITTER
SPEC-R REAR BUMPER/EXHAUST HEAT SHIELD
What do you think?
Ian.
Old Apr 14, 2004 | 12:22 PM
fookin minted mate, one of the best ive seen
Old Apr 14, 2004 | 12:31 PM
Ian3dr's Avatar
Ian3dr
2 more......
Ian.
Old Apr 14, 2004 | 12:46 PM
MM_RACING's Avatar
MM_RACING
Mint
Old Apr 14, 2004 | 03:19 PM
DanS2turbo's Avatar
DanS2turbo
Old Apr 14, 2004 | 03:33 PM
I think ive jus creamed my pants looking at that...
Absolutely fucking mint mate, superb car!!
Old Apr 14, 2004 | 03:52 PM
Hansenturbo's Avatar
Hansenturbo
F***** nice m8
Old Apr 14, 2004 | 03:53 PM
Jesus christ mate, i cannot believe how clean ure car is, its gorgeous! I take it you don't drive it in the rain often!?
Old Apr 14, 2004 | 03:55 PM
A fucking nice car M8!!!!!!!!!!
Old Apr 14, 2004 | 04:13 PM
Sapphy's Avatar
Sapphy
LMFAO!! Not laughing at you mate, it's just you don't know how far from the truth that is!
This car wasn't done just for the looks believe me!
What few people realise though was that this car has been lovely since it was built.
Ian took a nice car and made it better, then better still and then still not happy, he improved on perfection.
I have wet dreams that aren't as horny as this car is in the flesh.
Old Apr 14, 2004 | 04:28 PM
TIFF's Avatar
TIFF
Chasing Radders
Top one Ian,fucking loverly mate
Old Apr 14, 2004 | 05:08 PM
tkrath's Avatar
tkrath
TOOOP
Old Apr 14, 2004 | 05:36 PM
Fooking mint m8 ... very very wicked and clean.. Got any bigger pics of the car ?
Old Apr 14, 2004 | 06:13 PM
Darrone's Avatar
Darrone
Default Re: My 400bhp 3dr Cosworth
Originally Posted by Ian3dr
What do you think?
What do I think??? I think it's the best god damn 3 door I have ever fucking seen!!! That's what I think!!!!
Old Apr 14, 2004 | 07:12 PM
RSrussell's Avatar
RSrussell
Very nice ian.....as always
Old Apr 14, 2004 | 07:32 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Minter!
Old Apr 14, 2004 | 07:34 PM
alan rainbow's Avatar
alan rainbow
one of the best
Old Apr 14, 2004 | 08:23 PM
Dunccoss's Avatar
Dunccoss
Hi ian spotted some dirt under your car then i looked again and realized it was your cap on your head, looks like your ready for the pod fancy runing up the pod in the afternoon i know you want to and i will join you aswell.
cheeRS MATE DUNC Bring home top spot for the northants group
Old Apr 14, 2004 | 10:12 PM
RobS's Avatar
RobS
awesome ian truly awesome
def my fav 3dr
Old Apr 14, 2004 | 11:12 PM
Ian lookin fookin lurverley as usual
Old Apr 14, 2004 | 11:24 PM
stickertone's Avatar
stickertone
looking good billy ray!!!!!
Old Apr 15, 2004 | 12:37 AM
Ian3dr's Avatar
Ian3dr
Thanks for the comments!
Had the car coming up for 4 years now, it was a totally mint standard car all bar a stage 1 chip, 39,000 miles. Had an all new 350bhp engine built, which I killed 6000 miles later at Bruntigthorpe, so had this 400bhp engine built by Harvey, it went in last summer. The car had a few nigaly imperfections in the bodywork, so starting from the underside, it has been fully restored, and the only thing not modded is the gearbox (yet ) It was featured in last months Performance Ford and this months Fast Ford with 3drbadboy (Ant), but it had my old Hockenheims on then. Spent FAR FAR too much money on the car over the years , but its all done now, well nearly .
Dunc, yes I probably wont be able to resist temptation on Sunday, so I will see you on the strip! Will be an interesting race
Ian.
PS..... My old Hocks are for sale if anyone wants them........
Old Apr 15, 2004 | 06:44 AM
HOLY CRAP THAT'S FINE!
20 thumbs up!
Old Apr 15, 2004 | 08:16 AM
i want it please please
Old Apr 15, 2004 | 08:18 AM
Ryan's Avatar
Ryan
i soooooooooooooooooooooooooo want this car!
Old Apr 15, 2004 | 09:09 AM
DanS2turbo's Avatar
DanS2turbo
It's got to be the Pamala Anderson of the car world! Getting on a bit now, but very moddified, still bloody gorgeous!.... & everyone wants a go!!
Old Apr 15, 2004 | 09:56 AM
TIL13R's Avatar
TIL13R
car is fooking mint!
Old Apr 15, 2004 | 10:54 AM
klebbe's Avatar
klebbe
O my God , many hours of your life in that car I am very impressed ! The car lokes lovley
Old Apr 15, 2004 | 11:21 AM
JamesH's Avatar
JamesH
1 of the best i've seen mate well done!
Old Apr 15, 2004 | 11:44 AM
DannyC's Avatar
DannyC
Got to be the best i've seen, well done mate looks alot better on the new rims
Old Apr 15, 2004 | 02:04 PM
1st-ly, Well done..... thats the best i've seen that's that modded!
2ndly the wheels....... Don't wanna cause an issue, cos u guys know wot looks better on these then me...... But wouldn't it look even better with some nice Azev (Oh forget the name of the wheel but the same as on dunccoss's escort in his signature above)????
Mind you, with a car that MINT s'pose the wheels are no longer such a big issue!
oski
Old Apr 15, 2004 | 02:17 PM
Ian3dr's Avatar
Ian3dr
Oski..... Hi mate, thanks for the comments Regarding the wheels, when you fit big brakes on the front of a 3dr (mine has 6 pots), finding a wheel that clears the caliper is difficult. I had Hockenheims on there before, and I had to modify the caliper so they cleared, and run 2mm spacers, which then alters the offset, thus ruining the handling Motorsport rims have no clearance issues, and out of the choice, Mo's are the best
Heres the car with the Hocks on last year......
Ian.
Old Apr 15, 2004 | 04:15 PM
B11GNS's Avatar
B11GNS
Mint that is Like them wheels too, best colour me thinks.
Old Apr 15, 2004 | 05:07 PM
That’s an absolute cracker the 405bhp decal is a nice touch
Old Apr 15, 2004 | 05:35 PM
Wow mate that is unreal
Old Apr 15, 2004 | 05:45 PM
Rich's Avatar
Rich
Love ot mate
Fooking lovely
Rich
Old Apr 15, 2004 | 06:06 PM
martinrs500labatts's Avatar
martinrs500labatts
very nice!!
Old Apr 15, 2004 | 06:08 PM
Old Apr 15, 2004 | 07:54 PM
righthooker's Avatar
righthooker
great car ,if i had a digital camera i could snap mine then you could all see the very best and worst cosworth
Old Apr 15, 2004 | 09:43 PM
lovely car m8
