rear cossie Ap 4 pot kit £500 delivered
I have for sale a set of ap 4 pot calipers (cp5100) and a pair of 295x25mm discs complete with nearly new pads
In good but used condition,
Comes with bolts and mounting brackets to fit a standard escos rear beam and maybe grpa square beams? they were removed from a escos track/rally car i was told, so bare in mind that the brackets may be ok but may need modding, would need a seperate handbrake caliper if you want/need to run one but any ap kit would regardless,
all bolt and mounting measurements are listed below for you to double check, but with new brackets and bells these would fit anything,
Only selling as these foul my custom rear steering arm set up and I have to use a 330mm disc
KIT INFO -
DISC SIZE IS 295MM
DISC THICKNESS REMAINING -24.9MM
PAD THICKNESS REMAINING 11MM
BELL PCD IS 12 X 177.7MM
BELL OFFSET IS 20MM FROM HUB FLANGE FACE TO OUTER FACE OF DISC
BRACKETS
130MM BETWEEN CENTERS FOR CALIPER MOUNTING HOLES
90MM BETWEEN CENTERS FOR BEAM MOUNTING HOLES
If you need any more info please ask
Just want to get back what i paid for them and the new bolts last week
£500 delivered
KIT INFO -
DISC SIZE IS 295MM
BRACKETS
£500 delivered
It is a bargain for anyone even if you had to make new brackets to suit a different car etc
Just gutted to sell as it was exactly what i wanted for a great price but i never realized i had to use 330mm discs due to my rear set up
Waiting to hear back from another member but it's 1st come 1st served im afraid as i cant afford to buy the bigger stuff till this is gone
I bought these from MT_MOTORSPORT an he told me these were removed from an escos rear beam,
I can give you any measurements you need to double check, but most sizes you need to know are listed above
Bttt
I have dropped the price again as i bought some 325mm discs today and they come with good used bell fixing cap head bolts with proper locking nuts so i am now keeping the new bolts i bought for my new set up and this kit will come with the older style ap cap head and lock nuts as pictured above
£520 delivered to mainland uk, but will post else where for extra
Or £500 collected from Essex SS12
Thanks
Marc
Thanks
Marc
Oct 9, 2015 07:38 PM
