whats the best saph off sets
Dec 19, 2011 | 09:00 PM
as above whats the best off set on 17x8 rims on a saph i don't mind if front and rear are differant just want to fill the arches but not rub
thanks in advance
Dec 19, 2011 | 09:06 PM
I'd say ET35 mate but I have 18x8 Wheels
Dec 19, 2011 | 09:09 PM
sit's nice with the arches that
Dec 19, 2011 | 09:56 PM
Dec 19, 2011 | 10:13 PM
This is E33 on 8x18 ...
And this is E30 on 8x17 ...
Dec 19, 2011 | 10:31 PM
Quote:
Originally Posted by
Ridgey
et32 IMO.
Mine too
Dec 20, 2011 | 09:39 AM
Dec 20, 2011 | 09:46 AM
so where between et32-et35 for 8inch wide wheels
Dec 20, 2011 | 10:37 AM
Nice wheels '2wd', mine are 16" though.
Dec 20, 2011 | 10:40 AM
damien roe
For the front yeah, but to fill rear arches i'd go more. I run et25 rear which fill the arches a bit better. I did run et15 before that. Quick pic
Dec 20, 2011 | 02:40 PM
i'd say anywhere between et32-35 and if your car is lowered you might want to correct the negative camber so the wheels sit flush.
A few people off here are using camber shims to sort this
Dec 20, 2011 | 06:38 PM
R4N S S
whats these camber shims i never saw them
Dec 20, 2011 | 06:55 PM
they go between the the rear hub and trailing arm damo,
washers do the same job but
Dec 20, 2011 | 06:58 PM
If your getting 17x8 go for 225/35 tyres all round, make use of the 8 width.
Dec 20, 2011 | 06:59 PM
DAN400
where do you get the shims
Dec 20, 2011 | 07:06 PM
rainbird sells them i think, not 100 % sure
Dec 20, 2011 | 07:09 PM
xr_craig
That's more like it
Dec 21, 2011 | 01:19 PM
Most of the shims are for toe, nothing to do with camber at all.
dojj
28
Sep 11, 2015 10:00 PM
3doorcozmess
Sep 7, 2015 01:32 PM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
17x8 ,
2wd ,
3dr ,
75x17 ,
camber ,
cosworth ,
et15 ,
passionford ,
saph ,
shims ,
sierra ,
wats ,
whats
