whats the best saph off sets
as above whats the best off set on 17x8 rims on a saph i don't mind if front and rear are differant just want to fill the arches but not rub:king:
thanks in advance |
sit's nice with the arches that:king:
et32 IMO.
This is E33 on 8x18 ...
http://i3.photobucket.com/albums/y52...h/braid008.jpg http://i3.photobucket.com/albums/y52...h/braid007.jpg And this is E30 on 8x17 ... http://i3.photobucket.com/albums/y52.../iiii005-1.jpg |
Originally Posted by Ridgey
(Post 5738119)
et32 IMO.
Mine are 7.5x17, et 37
so where between et32-et35 for 8inch wide wheels;-)
Nice wheels '2wd', mine are 16" though.:top:
Originally Posted by damien roe
(Post 5738414)
http://img.photobucket.com/albums/v1...0pics/et15.jpg |
i'd say anywhere between et32-35 and if your car is lowered you might want to correct the negative camber so the wheels sit flush.
A few people off here are using camber shims to sort this ;) |
Originally Posted by R4N S S
(Post 5738632)
they go between the the rear hub and trailing arm damo,
washers do the same job but |
If your getting 17x8 go for 225/35 tyres all round, make use of the 8 width.
Originally Posted by DAN400
(Post 5738915)
rainbird sells them i think, not 100 % sure
Originally Posted by xr_craig
(Post 5738457)
For the front yeah, but to fill rear arches i'd go more. I run et25 rear which fill the arches a bit better. I did run et15 before that. Quick pic
Most of the shims are for toe, nothing to do with camber at all.
© 2024 MH Sub I, LLC dba Internet Brands
