2wd will not start
Old Dec 15, 2011 | 05:03 PM
paduk's Avatar
paduk
Default 2wd will not start
Greetings from Italy
Sorry for my English, but I use the translator, any complaint to let it Google!
My, always, sierra cosworth 2wd 1989, decided not to start more.
I keep my car in the garage, and when I can light it up every month.
The last time I turned it off regularly, but when I tried to start it the following month, the starter motor turns, the noise "zzzzzzz" is heard, the ABS warning light goes off, but will not start.
After several attempts I have seen the indicator pointer of gasoline to go down slowly and is no longer rising.
I checked all fuses, relays lubricated, but I did not get anything.
And 'ever happened to anyone?
Do you have tips?
thanks
Old Dec 15, 2011 | 07:50 PM
LHD220Turbo's Avatar
LHD220Turbo
can you hear the fuel pump start when you turn ignition on?
in the boot where the spare wheel is, you have a fuel cut off switch. make sure this has not triggered
Old Dec 16, 2011 | 12:18 PM
martysmartie's Avatar
martysmartie
The sound is the starter motor, it sounds like it may be attempting to fire but it cannot.
There is a fuse which controls the whole dash, if this were corroded etc you would have no lights etc.
Most likely you have a sender problem, assuming the fuel isn't actually being consumed/leaked etc?
I should think you have fuel, but perhaps the ignition system is damp etc?
Martin
FlashRS
13
Aug 31, 2015 06:02 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
