Wheels and Tyres Wheels and Tyres for all Ford's
16inch alloys on brembo calipers???help
Old Dec 13, 2011 | 09:21 AM
lindabop's Avatar
lindabop
Default 16inch alloys on brembo calipers???help
can some one tell me if 16 inch alloys will fit on our mondeo st 2006 (all standard apart from the BREMBO calipers).
Was planning a set of smaller alloys and winter tyres for the winter, was just about to order them but they werent sure if 16's will fit with the brembo calipers, any help gratefully recieved?
Old Dec 13, 2011 | 10:17 AM
homer j's Avatar
homer j
remind me, what size discs do they have? think anything above 310mm you might struggle. that said if you use the team dynamics that christian had on his rs turbo you can get upto 330mm just about.
Old Dec 13, 2011 | 10:24 AM
lindabop's Avatar
lindabop
i have no idea! will need to ask the other half when he gets home!
Old Dec 15, 2011 | 04:47 PM
graham c's Avatar
graham c
daz c off here runs 330 ap under 16'' comps but their motor sport wheels
Old Dec 17, 2011 | 09:06 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'm going to be fitting 324mm discs with brembo four pots in the next week, all under 16" Rota alloys. i know a little work on the caliper is needed, all of 1.8mm to get clearance i've calculated on two small areas.
Old Dec 20, 2011 | 12:37 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
just had a quick play and they will just fit under my rota 16" wheels. the wheel weights are a bit in the way and as such will need a little shaving off the calliper.
they will be a tight fit, but doable.
Old Dec 20, 2011 | 03:01 PM
R4N SS's Avatar
R4N SS
i had to shave the caliper down on my saph to get them under the 17s
Old Dec 22, 2011 | 10:50 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i do run a 5mm spacer too, but only a couple of mm clearance issue
Old Jan 18, 2012 | 12:49 AM
zippyobrien's Avatar
zippyobrien
ive got et25 16x7 comps and they fit over my 330mm discs and evo brembos JUST lol
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
