xr2, frs, rst parts for sale
Bodger of Blackburn
just a few bits to clear to raise funds again.
complete cosworth 4wd front brake setup, bolt on kit (with bolts too!) mintex pads, 278mm discs in good condition. 15" wheels ideally needed.
looking for around £160 ready to fit to an xr2/mk2 fiesta
mk2 passanger wing mirror, not remote glass intact £5
ferrodo brake shoes, with some new adjuster bits for mk2 fiesta £18
erst t3 turbo, not a smoker IIRC, bit of play in shaft removed for a bigger unit moons ago, needs a clamp for exhuast/inlet side can't remember to be honest will have a look later £70
ERST exhaust manifold £20
3" 316 stainless mandrel 90degree bend 1.6mm side walls £15
ERST t3 downpipe flange and clamp, useful if you're making your own exhaust system £3
xr2 etc starter motor, great unit £20
mk2 rear quarter glass with seals £10 each side
mk2 fiesta boot glass with rubber £20
Focus RS mk1 Brembo 4pot callipers, good condition no pins sadly £150 ono
that's all i can think of for now for parts.
JK12
33
Apr 26, 2021 12:09 PM
