ST vs normal focus
Old Dec 7, 2011 | 05:29 PM
danme1987's Avatar
danme1987
Default ST vs normal focus
Are there any differences between these parts between the ST170 and standard focus models:
Steering rack
Roll bars
Need to know for a conversion
thanks
Old Dec 7, 2011 | 06:16 PM
hogdog's Avatar
hogdog
Steering rack is the same but it's shorter or has a limiter to stop the larger tyres (45 profile rather than 40 profile as fitted to special editions with 17" wheels) from rubbing.
Anti roll bars are the same.
Old Dec 7, 2011 | 08:35 PM
danme1987's Avatar
danme1987
would you not bother changing it then?
Old Dec 7, 2011 | 11:17 PM
hogdog's Avatar
hogdog
Nope, I'd just fit 40 profile tyres. You may even get away with some manufacturers 45 profiles without rubbing, Ford were just covering themselves. It will have a better turning circle, the ST170 is pretty bad for that.
massivewangers
30
Oct 1, 2015 07:40 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
richierich1986
Sep 18, 2015 03:29 PM
tib2220
Sep 14, 2015 12:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
