driveshaft problem
can anyone confirm that xr4x4 front driveshafts are longer than normal escos fronts??
having fitted new coilovers, i ve been playing around, until i thought id found a nice ride hieght at the front, and then as you can probably guees, my o/s shaft, split under acceleration!!
are they as strong as well??
cheers
cheers
They are longer m8,as for as strong not sure but a lot of people use them on cosworths.
Check your engine mounts first m8,had this prob on my 4x4 saph and both mounts were fooked
Jack engine up and see if it lifts off mounts m8
James,
hi mate.
i fitted the xr4x4 one on my car ages ago and have had no probs since.
these are about 25mm longer.
Can get a used one complete for about Ł30! from a scrap yard/breakers.
As above check the mounts.
Dave.
hi mate.
Dave.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
