oil from dump valve
Old Feb 20, 2005 | 08:44 PM
krisberic's Avatar
krisberic
Default oil from dump valve
Ive noticed a bit of oil coming from where the dump valve lets the air out, alsowhen i took the garge pipe and hose off there was a slight bit of oil in there too, is this normall. It doesnt smoke on idle or at full boost or even whe its been stood over night.
Old Feb 20, 2005 | 10:53 PM
AKRS1's Avatar
AKRS1
i think a slight bit of oil is fine as most rs turbo have it dont forget the youngest rs turbo is 14 years old so you are bound to find a small amount
Old Feb 21, 2005 | 09:45 AM
Stoo's Avatar
Stoo
Yeah small ammounts of Oil is OK.Too much though and it could be the oil seals on your Turbo
Old Feb 21, 2005 | 11:34 AM
Rob84's Avatar
Rob84
i had oil coming out of mine too, and it stunk every time it went off and was making a mess of the engine bay. so i ditched it and i'm not running with out one
Old Feb 21, 2005 | 03:21 PM
james_birch's Avatar
james_birch
But that doesnt cure the problem! (tho im with you 100%) cus now rather than oil goin in ya engine bay its just glogging up ya intercooler and inlet!!
I would recomend taking off ya top boost hose and checking it!
Old Feb 22, 2005 | 06:52 AM
Rob84's Avatar
Rob84
when i said a mess, i didnt mean its was all over, just was creating a gold patch on the underside on the bonnet and misting over the rocker cover. checked in the boost pipe and theres hardly anything, nothing worth worrying about
Old Feb 22, 2005 | 05:55 PM
CarlRsT's Avatar
CarlRsT
Indeed it wont it could be caused by back pressure in your block (oil rings) blocking the dump valve wont stop this as it will find the next easiest place to escape from like dip stick, rocker cap metering head return!!
It may not be that bad and like others have said a small amount is norm but keep an eye on it
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
RS-Rikki
Sep 21, 2015 07:27 AM
coscor86
Sep 20, 2015 01:21 PM
rs_jim
Sep 19, 2015 08:41 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
