brake question
Old Nov 27, 2011 | 04:15 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Default brake question
Hi all, this may of been asked before but is it worth having std four pots up front and 4x4 vented discs and calipers at the rear? Thanks.
Old Nov 27, 2011 | 05:27 PM
martysmartie's Avatar
martysmartie
Only in terms of heat disipation, as the solid discs will get very hot if driven enthusiastically, remember if you do this you will also need the calipers as well.
Martin
Old Nov 27, 2011 | 06:30 PM
DixieTheKid
Pick-up P100 Power!
Many thanks
Old Nov 28, 2011 | 02:16 PM
Char1ie's Avatar
Char1ie
On track my 2WD rear set-up caused the pads to disintegrate very very quickly. Changing to vented rear and 4WD calipers made the pads last much longer on track.
Prickly_buzz
Dec 7, 2017 09:52 PM
155lee
Oct 27, 2015 04:55 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
Sp3no
Sep 27, 2015 07:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
