3.9 ratio 2wd diff
for sale £offers i have a complete diff minus driveshaft flanges the case has been machiened out to accept a gripper lsd comes as in pictures or will sell parts individually if required the pinion gear has some small pitting marks on it as in the photos these were only discovered when the gear was removed from the case but everything else is in good working order cheers danny 07788 426 271
I think someone should rip your arm off at that price !
Did you use it ? my mates had some small marks in it and it made a LOT of noise off load, if you did use it and it was quiet then thats a bargain IMO
i have not used it mate it came in the spares package when i bought my racecar i was going to get a gripper lsd fitted in it so i could swap between 3.6 and 3.9 ratios for diffrent curcits but now i plan to get a elite sequential box and its easier to change the drop gears in the box so it is surplus to requirements
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
