ESRT Rear link kit question?
Old Feb 20, 2005 | 04:19 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Default ESRT Rear link kit question?
Is it possable to fit a ajustable rear link kit without coilovers and just use Koni's on the rear of a ERST?. Also what do you do about the rear anti roll bar and load sensing valve?
Old Feb 20, 2005 | 04:39 PM
Rick's Avatar
Rick
you have to use coilovers, as there is no room for the spring platform to go.
Old Feb 20, 2005 | 04:44 PM
Tim's Avatar
Tim
depends what you want to adj if its toe in out yes.
Old Feb 20, 2005 | 04:48 PM
Rick's Avatar
Rick
think he means the parraled arm kits which stop the rear wheels steering
Old Feb 20, 2005 | 05:33 PM
Johnny Knoxville
the full kit like nuts r us's
Old Feb 20, 2005 | 05:45 PM
NUTS RuS's Avatar
NUTS RuS
Its possible if you go for the rose jointed rear arm instead of the full rose jointed adjustable bar set up. This leaves the rear anti roll bar in place, for those that deem it to be necessary.
I used to run my car this way before going fully Group A
edited to add an old picture.
The inner end of the rear arm is rose jointed to re-adjust the camber. It was sat on home made Koni coilovers at this point, and take it from me they (the Koni's) were one of the worst mods I ever did to the car.
I still didn't run a rear ARB tho even with the rear arms on.
Old Feb 21, 2005 | 04:34 PM
Johnny Knoxville
What about the brake load valve?
Old Feb 21, 2005 | 04:52 PM
NUTS RuS's Avatar
NUTS RuS
Cars piped front/front and rear/rear with a bias adjuster (pressure reducer) in the rear line so it dosn't need them
Old Feb 21, 2005 | 05:22 PM
Johnny Knoxville
You couldn't do a simple deawing of the brake pipe lay out shout be like? also the car has ABS
Old Feb 21, 2005 | 05:29 PM
NUTS RuS's Avatar
NUTS RuS
Not so easy sorry mate as mine has the MEF bias pedal box fitted too. Martins looking at making a direct fit one for Escorts, so these mods can be easily done then
Old Feb 21, 2005 | 05:33 PM
nigel b's Avatar
nigel b
junk the abs as it is crap
that does away with the rear load compensator
DAN@ADRIAN FLUX
Insurance
15
Jun 30, 2018 09:00 PM
YODI
Aug 30, 2015 01:12 PM
borboyous
Aug 22, 2015 11:17 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
