Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
1.8\ 2.0 mix match?
Old Nov 24, 2011 | 09:38 PM
hutch91's Avatar
hutch91
Default 1.8\ 2.0 mix match?
Heres what iv been thinking of doing if anyone knows any probs with this would really appreciate the comments ,
2.0
Block, cams, box
1.8 head, aux's, managment (get it re-mapped)
Would this be worth doing? I have both engines to mix and match, any better plans? Thanks guys
Old Nov 24, 2011 | 10:02 PM
hogdog's Avatar
hogdog
There's no real problem with that plan (except that the 1.8 and 2.0 cams are the same), using the 1.8's head will raise the compression very slightly but I don't think it's worth the bother of swapping the head, I'd just use the 2.0 stuff and add the 1.8's injectors so you won't need a remap.
Old Nov 27, 2011 | 10:35 PM
Cozziekid's Avatar
Cozziekid
No real benefit from adding the 1.8 stuff to the 2.0 - keep the 2.0 as is IMO. The 2.0's MTX75 box is a stronger unit if your planning on more power down the line.
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
gingeRS
17
Oct 2, 2015 09:42 AM
The Enigma
Sep 29, 2015 10:31 AM
