RWD Escort Cosworth
Old Nov 24, 2011 | 08:51 AM
3FRD's Avatar
3FRD
Default RWD Escort Cosworth
Has anyone done a how to guide on converting an Escos to RWD?
Old Nov 24, 2011 | 07:52 PM
NEIL A's Avatar
NEIL A
Kev sharp did one on here a while ago with a full list of the parts needed, he did hs with 3door front hubs and a few other parts that alot of people dont normaly fit.
Old Nov 25, 2011 | 06:28 PM
WongRS's Avatar
WongRS
i am in the middle of it (4x4 saff), and finding these 2 helpful
http://www.escortrscosworth.com/foru...ad.php?p=68596
https://passionford.com/forum/genera...rear-beam.html
I am doing the cheapo method of just using the outer joins in the front 4x4 hubs though.
sure you need a shortened prop on an Escos too.
Old Dec 9, 2011 | 07:17 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Don't do it Casse, you'll have it broadside EVERYWHERE if you do
Old Dec 9, 2011 | 08:33 PM
3FRD's Avatar
3FRD
Thanks for the pointers guys. What you on about AGAR? haha.
Old Dec 9, 2011 | 09:02 PM
AGAR-COSWORTH
Redumbdancy
Ha ha
What would happen to your front quaife diff if you went RWD?
Old Dec 10, 2011 | 09:38 PM
3FRD's Avatar
3FRD
Originally Posted by AGAR-COSWORTH
Ha ha
I would keep it as a memory of it being 4wd?? Lol. I'd sell it on here....
Old Dec 11, 2011 | 08:17 AM
jay's Avatar
jay
Do it mate love mine!
Old Dec 11, 2011 | 04:40 PM
jessie_rs's Avatar
jessie_rs
yums rear wheel drive now?
Old Dec 11, 2011 | 07:01 PM
jay's Avatar
jay
whos yum?
cant wait to take that plate off lol
Old Dec 14, 2011 | 02:47 PM
COSSIEGAZ's Avatar
COSSIEGAZ
trust you jay lol
Old Sep 11, 2012 | 01:50 AM
3FRD's Avatar
3FRD
Away to make a start on this soon, got all the bits
Old Sep 12, 2012 | 07:20 PM
bluebones's Avatar
bluebones
ive just finished doing mine last weekend, and just some pointers for you, when using the 2wd sump, change the pick up pipe and oil pump to 2wd, as me and a few other people have had problems when fitting the sump, causing the 4x4 pickup pipe to be hitting the crank, and trust me, u dont want to be doing this twice like i did.
Also its either 6 or 8 washers to space the crank sensor, ill have another look and let you know, and no need to change the front hubs, just take the shafts out, 2wd prop will need to be shortened, and gearbox cradle will need to be changed,again ill hunt the part number out as only about £25 from fords.
hope it all goes well for you.
Old Sep 12, 2012 | 08:27 PM
booner999's Avatar
booner999
mine is RWD, I owned a 4x4 and the RWD is alot more fun
Old Sep 14, 2012 | 04:43 AM
3FRD's Avatar
3FRD
Thanks for that One thing is did you change to a 2wd dipstick or is the escos one the same length?
Old Sep 15, 2012 | 06:08 PM
bluebones's Avatar
bluebones
kept the same one, no need to use a 2wd one.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
