q for rod or any aero boffins
Old Nov 24, 2011 | 07:22 AM
scoooby slayer's Avatar
scoooby slayer
Default q for rod or any aero boffins
800 kg kit car.
600 lb v8 up front but behind front axle so weight around 50/50 200 kg on each corner, will have rear spoiler aswell which should give some downforce.
at 130 mph for straight line stability what else should i be looking at or should it be ok ?
Old Nov 24, 2011 | 07:33 AM
fraser9764's Avatar
fraser9764
How easy would it be to get the floor flat and a diffuser under the back end?
Old Nov 24, 2011 | 07:43 AM
scoooby slayer
diffuser woud be troublesome as its all back axle its huge lol.
i could ali panel the floor though with just 2 holes for sump pan and gearbox belly.
the body sits alot lower at the front than the rear aswell which i guess will help to get the air out quick from under it.
Old Nov 24, 2011 | 09:20 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
At only 130mph and in a straight line, I really cant see you having a problem.
Old Nov 24, 2011 | 09:32 AM
Joshy's Avatar
Joshy
Dreamer
Just tracking I would say....
Old Nov 24, 2011 | 09:52 AM
scoooby slayer
thats good to hear maybe im being over cautious then i genuinely dont know at what mph it becomes an issue, i dont have the private facilitys to get above about 80 mph inless i can get on an old dissused runway.
il get it 4 wheel aligned aswell as ive just done it with a tape measure and wood lol
Old Nov 24, 2011 | 09:53 AM
scoooby slayer
that defo needs doing ive guessed it by eye lol
155lee
Oct 27, 2015 04:55 AM
little bram
Sep 27, 2015 07:45 AM
IainRS1700T
Sep 25, 2015 06:44 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
little bram
Sep 10, 2015 10:45 PM
