GT3076HTA turbo
Old Nov 22, 2011 | 07:43 PM
Trist's Avatar
Trist
Default GT3076HTA turbo
what are they like on a yb? apparently a company called owen developments take a GTX30 ad uprate the weak parts making the HTA model
my father in law has ordered one for his 4x4 sapph
what is needed to run it on 2wd manifold with Tial 44mm external wastegate?
anyone got pictures of one fitted?
Old Nov 23, 2011 | 07:33 AM
GUZZLER's Avatar
GUZZLER
Not seen one on a YB but I have something similar on my focus, Owen's GT3076r with the metal caged bearings, anodised red billet comp wheel etc, seems to work ok, not cheap though!
Old Nov 23, 2011 | 08:10 AM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
The HTA was around before the GTX from what I remember.
Effectively it's an extended tip billet wheel which allows greater efficiency at higher boost.
They're ideal if you intend on running 2.5 bar held.
Old Nov 23, 2011 | 08:46 AM
Trist's Avatar
Trist
Cheers this one going on an A1 built engine with 6 long studs Swedish inlet bd14 inlet std exhaust cam. up rated head and multi layer gasket. Think he paid 1500 for it.
Old Nov 23, 2011 | 09:54 AM
pieterjan's Avatar
pieterjan
Who is mapping the car?
Old Nov 23, 2011 | 10:04 AM
Trist's Avatar
Trist
Not sure yet enhanced performance or what they are called now done it last time.
Old Nov 23, 2011 | 10:10 AM
pieterjan's Avatar
pieterjan
Is he still working for AFR? I payed him 1000£ for an ecu and loom 3 months ago and still haven't recieved it.
Old Nov 23, 2011 | 10:32 AM
DAN P's Avatar
DAN P
not again
Old Nov 23, 2011 | 10:45 AM
pieterjan's Avatar
pieterjan
Yeah i now i've bought some stuff in the past and never had any problems. I will go to the police to put a complaint against him for fraud.
Old Nov 23, 2011 | 10:57 AM
Trist's Avatar
Trist
Don't want to get into a tuner war so let's not go into that on here
It will end in another 20 page tuner row. Lol
Old Nov 23, 2011 | 12:22 PM
TimC's Avatar
TimC
Best going on MLR and seeing the results alot of had on there. Loads seem to run them
Old Mar 5, 2012 | 10:46 AM
AustenW's Avatar
AustenW
Any updates on the HTA turbo?
Old Mar 5, 2012 | 01:01 PM
Trist's Avatar
Trist
Only that it's turned up. It's like turbo porn to look at.
Not fitted yet. Engine getting built up. Oppliger gearbox also turned up along with 3part clutch small flywheel and hydraulic clutch system.
Should be interesting. Hoping to go see guzzler at power engineering in the next few months for mapping.
Old Aug 17, 2013 | 07:37 PM
Trist's Avatar
Trist
Bit delayed due to him having house extension.
But it's getting built up at the moment. Oppliger gearbox in. Head turned up with some fancy cnc profiled cams.
Been told to expect 500bhp 500 torque.
Ecu? Can you run this through standard?
Old Aug 17, 2013 | 09:06 PM
opposite lock's Avatar
opposite lock
Level 8 fine at that power live mapped .
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
