Wheels 18x9 engels 3 door ahmed spec springs
Old Nov 22, 2011 | 02:34 PM
tee-rex's Avatar
tee-rex
Default Wheels 18x9 engels 3 door ahmed spec springs
Set of engels 122 hs wheels 18x8.5 offset 18, rims in very good condition not the original paint as they have been white before, prob not the best finnish in the world but very presentable, all four caps locking screws and key included £375.00 plus £25.00 postage.
Set of 3 door ahmed spec (fast road) coil springs fronts never been out of the box rears trial fitted twice on axle stands, springs came from r&b motorsport. £120.00 plus £10.00 postage
Also have a full set of koni's for a 2wd/3dr fronts have std springs on them They are very tidy no leaks but the bump stops on the fronts are very perished sorry don't have any pics of them at the mo. £100.00 plus £20.00 postage
All postage quoted is for mainland uk only
Old Nov 22, 2011 | 03:43 PM
COCHYN's Avatar
COCHYN
Cheap quality wheels, look better without the centre caps
Old Nov 22, 2011 | 06:35 PM
STUCOS's Avatar
STUCOS
You sure these are 9" wide ?
Old Nov 22, 2011 | 07:37 PM
bigpower's Avatar
bigpower
Engels / Ronnies are 8.5 x 18 ET18
Good luck with the sale pal!
Old Nov 22, 2011 | 08:08 PM
Turbosimpsons's Avatar
Turbosimpsons
what size are they ?
Old Nov 22, 2011 | 08:20 PM
tee-rex's Avatar
tee-rex
inner edge of the bead to inner edge = 8.5 inches outer edge of the bead to outer edge = 9 inches, they had 235 tyres on them which looked a little stretched, i have a spare team dynamics wheel which is 8x18 and the engels are an inch wider hope that helps.
Old Nov 23, 2011 | 07:05 PM
STUCOS's Avatar
STUCOS
It should have size cast in centre under were centre cap goes,
cheeRS stu
Old Nov 23, 2011 | 10:14 PM
Rsmat's Avatar
Rsmat
The springs...how much will they lower my 3dr by..?
Old Nov 23, 2011 | 10:45 PM
tee-rex's Avatar
tee-rex
cheeRS stu
Had a good look at the centre section of the wheel with the most prominent cast marks and it reads 8.5x18 sorry for any confussion
Old Nov 23, 2011 | 10:54 PM
tee-rex's Avatar
tee-rex
When i spoke to mike rainbird he told me that the drop would be IIRC 20mm and he also advised to fit the shim plates between the hub and trailing arm at the same time to help with tyrewear.
Old Nov 27, 2011 | 04:14 PM
jay's Avatar
jay
hi mate where abouts are u located interested in the wheels?
cheers
Old Nov 29, 2011 | 10:45 PM
Rsmat's Avatar
Rsmat
Are the springs still for sale mate..? pm me if so as im interested.
Old Dec 1, 2011 | 01:09 AM
leo_cos's Avatar
leo_cos
Where are you based interested in the wheels.. Are they all straight with no buckles?
Old Dec 1, 2011 | 07:26 AM
tee-rex's Avatar
tee-rex
Based near newmarket in suffolk mate all the wheels are perfectly straight but as i said in the description i would give the finnish 8/10, i was going to fit them to my 3 door but the off set is too small even with heavily modded arches.
Old Dec 1, 2011 | 09:12 PM
leo_cos's Avatar
leo_cos
Pm sent
Old Dec 2, 2011 | 10:01 AM
tee-rex's Avatar
tee-rex
Wheels provisionally sold to leo cos
Old Dec 2, 2011 | 05:05 PM
tee-rex's Avatar
tee-rex
3 door springs sold to rsmat cheers
Old Dec 11, 2011 | 09:13 AM
jay's Avatar
jay
Hi mate did the wheels sell?
SmudgerByName
52
Jul 28, 2016 06:14 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
RsS2daz
Aug 14, 2015 05:26 AM
dal3door
Aug 13, 2015 06:55 AM
