Mk1 FRS Injector Flow Rate?
Old Nov 21, 2011 | 04:24 PM
Marc LJX's Avatar
Marc LJX
Default Mk1 FRS Injector Flow Rate?
As per title, any help would be greatly appreciated!
Currently fitting engine & box into my MK3 escort Track car and running on Omex. Could do to know flow rates so that they can send me a start up map!
Old Feb 7, 2012 | 09:59 PM
mac-euro-focus's Avatar
mac-euro-focus
Iv been trying to find the same out, from what I can find the standards are 440cc and that's at 270kPa.. Hope this helps
Old Feb 8, 2012 | 12:00 AM
HockeyNomad's Avatar
HockeyNomad
They max out about 350-360bhp running with a base fuel pressure of 270kPa (2.7Bar) @100% DC
which puts them around 500-550cc/min mark @3Bar, by my calculations
Most havent bothered to flow test them, and they are a ford only part and info on them is very scarce,
and as Siemens 660cc/min injectors can be had cheaply most use them as a lot is known about them with plenty info on the tinterweb, allowing a very accurate Injector model to be programmed into the ecu.
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
dalmarshall
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
Tank Mike
Sep 26, 2015 08:07 AM
