Best place to get Vag-Com?
Buy it direct from Ross-tech.
Whats it for? If its just for general clearing fault codes, adaptations etc then get an ebay cable and the lite version of the software (think its Ł69 iirc)
If its for professional/business use, then buy one of the packages from ross-tech. They do plenty to suit your needs.
Yeh thats obviously a pirated copy. I use a Ł12 ebay cable with a Ł69 copy of the software and its done everything I've ever asked of it.
Some of the pirated copies can be ok, but some of them are difficult to get working.
I just thought for Ł80 ish quid, it wasnt worth the hassle of messing around with dodgy copies
As above if its for older vehicles as this is what I have done.
If you want to do the newer vehicles though you need the lead with can-bus or something like that else you cannot read anything other than engine as I have just found out.
Latest version is VCDS-Lite 1.1
depending on what you want it for.
ive just bought 1 of the cheap ebay Ł15 jobbies.
i only want it to turn off the eml light on my missus golf.
its a stupid cat problem, 2 lambdas reading different but no prblems...
if you can wait a couple of days i will let you know if it works and how well
rsguy
44
Sep 29, 2015 03:29 PM
