Would you?
Old Nov 20, 2011 | 05:53 PM
parkus's Avatar
parkus
Default Would you?
Buy a car that has been re-shelled by Ford but they never stamped the VIN on the chassis? Ie, the VIN simply wasn't stamped on the chassis, NOT it was removed.
What problems could there be? The car in question has changed owners a few times and thus never had any problems.
Old Nov 20, 2011 | 05:56 PM
oriurbo's Avatar
oriurbo
sounds a little dodgy to me.
The main question is why did ford never stamp it???
Old Nov 20, 2011 | 06:14 PM
parkus's Avatar
parkus
It does sound dodgy I know
I can't help but think that a garage as reputable as Ford would miss out such an important detail, even if it was 20 years ago.
Is there any other ways of checking it's legitamacy - aside from certificate for the MOT that Ford would have to of done to put it back on the road, proof of past owners, etc..
Old Nov 20, 2011 | 06:27 PM
phil_focus's Avatar
phil_focus
why would ford even bother reshelling a car??
sounds odd to me unless its something rare and very expensive in which case they wouldn't miss out the vin!!
Old Nov 20, 2011 | 06:54 PM
stevos's Avatar
stevos
Am sure there were a few cossies reshelled by ford back in the day.
Old Nov 20, 2011 | 07:00 PM
parkus's Avatar
parkus
First owner put it in a ditch apparently.
Old Nov 20, 2011 | 07:56 PM
St3V3_C's Avatar
St3V3_C
Dodgy.
Old Nov 20, 2011 | 08:02 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Is it really SO special/rare that you couldn't hold out and wait a little longer for a straight example of the same model?
Cheers,
Grant
Old Nov 20, 2011 | 08:59 PM
trev1964's Avatar
trev1964
Seen a few reshells from Ford over the years.
Never usually stamped.
Did usually have a vin tag on the slam panel stating replacement shell supplied with panels, or similar.
Old Nov 21, 2011 | 12:26 PM
phil_focus's Avatar
phil_focus
any paperwork to back this up?
can ford check against the v5 etc?
Old Nov 21, 2011 | 12:58 PM
tee-rex's Avatar
tee-rex
Saw a transit pick about a year ago with no vin stamped which had rolled apparently when it was three weeks old, it was re-shelled by tc Harrison with all the paperwork with to support the work strange why it's not stamped with either the old vin or a new one to denote a re-shell, apparently it was their demonstrator van.
