Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus Newbie
Old Nov 20, 2011 | 04:27 PM
chrisbrew's Avatar
chrisbrew
Default Focus Newbie
Hello I have just bought a 2002 Focus 1.6 zetec ghia. I have noticed a couple of problems since bringing it home. When I have the wipers on intermittent they dont work. I can hear the relay clicking but nothing happens. Also when coming to a stop the engine seems to have a very low idle speed causing the car to shake a bit but not cutting out. Having never owned one, is this normal? Not sure if this model has heated mirrors if so will they come on with the heated rear/front screens? Any help would be appreciated!
Old Nov 20, 2011 | 04:44 PM
martysmartie's Avatar
martysmartie
They do idle very low when coming to a stop but so long as it dosen't stall your ok, ime the more load, i.e. headlights etc on the more apparent it is.
Yes it will have heated mirrors and they are powered on with the heated FRONT screen, incidentally the washer jets are also heated!
Not sure on the wipers, maybe a loose connection, as the relay is clicking, it would seem the problem lies after this?
Martin
Old Jan 5, 2012 | 05:45 PM
Mehan's Avatar
Mehan
for the idle issue it may be your idle control valve needs a clean but usually should be at around 800rpm on stopping. not sure on wipers mate
Old Jan 5, 2012 | 06:20 PM
gouch1's Avatar
gouch1
welcome....
there is a switch located in the plastic cover of the wiper motor gearing case witch can go faulty and cause a loss in wiper motor functions either intermitent or casuing the wipers to stop anyware on the screan or total loss of wipers
somtimes this is casused by the switch overheating when the wipers have been used on a frozen screen and forced across it.
as for the rough idle it could be the idle control valve as said
Old Feb 6, 2012 | 08:28 PM
Focus_2008's Avatar
Focus_2008
Steve_2009
As previously said, the idle speed on a Focus is low as a general rule nething from 800rpm when at full temp upto 1200 when cold. With your wipers, my wiper relay actually went on mine as wouldnt go on intermittent but worked normally otherwise, replaced the relay (bout a tenner from Fords) works a treat now n had no probs since
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
