New turbo
What would be a good turbo for this spec
Standard head with bd14 inlet cam
200block with standard comp valve cut pistons
Grey injectors
500 cooler etc
I was wanting 400bhp and thinking of a gt series turbo. Possibly a gt2871 or a gt30?
Anyone run either of these and what rpm do they come on boost
Grey injectors
500 cooler etc
I think my t34 is on the way out as in getting oil coming out of the Amal valve. I take it it must be picking up out of the compressor side as the oil couldn't come from the actuator.
I have std engine, RS500 IC, greens. I spotted a T34 turbo for sale. Its garrett new T3/4 with these specs: 50/54 60ar/0,63 700€. Should it be good choice to acquire 330-350 bhp with reasonable boost, if I happen to buy it. Seems to be same specs as Escorts T34?
t34 0.48 will struggle to get to 400bhp - needs the 0.63 exh housing to make it - even then it will only last 12-18 months at the boost required for that power. You will spend 5-600 quid everytime on a rebuild, every 12-18 months
Not worth it imo, you will be better goin for a bigger turbo that can handle 400bhp easily.
+1......
Mine runs a T34.63, 200 block, 7:8:1 Mahle's with valve cut outs, Light Blues, standard head etc. and runs a shade under 400 with similar torque. Awesome setup and not laggy at all, perfect drivers package IMO
JK12
33
Apr 26, 2021 12:09 PM
