Dash mounted fuel pressure gauge
Old Nov 19, 2011 | 06:36 PM
CHUNKYS RS's Avatar
CHUNKYS RS
Default Dash mounted fuel pressure gauge
does anyone run one on a cosworth as i would like to keep an eye on the pressure if so what is a good make and how do they connect to the fuel rail ???
Old Nov 19, 2011 | 06:44 PM
andy escos's Avatar
andy escos
a mate of mine used to use one of these on his saff
http://www.ebay.co.uk/itm/SPA-Techni...1#ht_694wt_700
i welded on a 1/8th npt boss onto the fuel rail to fit the sender .
Old Nov 19, 2011 | 06:54 PM
St3V3_C's Avatar
St3V3_C
I have an SPA also - but to measure fuel pressure and oil temp.
Escort has plastic lines that you can cut into and fit a compression tee to, to connect the sender.
Old Nov 19, 2011 | 06:57 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I use a Stack Fuel Pressure 0-7 bar.
Old Nov 19, 2011 | 07:04 PM
CHUNKYS RS's Avatar
CHUNKYS RS
how did that connect to the fuel system
Old Nov 19, 2011 | 07:07 PM
St3V3_C's Avatar
St3V3_C
He handed over money, and there it was.
LOL.
Old Nov 19, 2011 | 07:15 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
If you want to see a fuel pressure gauge in the car - then make sure you get one with an electronic sender so the only thing you have running into the cabin is wires and not a capillary fuel line.
If it chafes through you'll have 3bar+ fuel being sprayed everywhere!
Stack do some good ones.
Old Nov 19, 2011 | 07:32 PM
CHUNKYS RS's Avatar
CHUNKYS RS
LOL.
how did it CONNECT not how did that work!!!!!
lol
Old Nov 20, 2011 | 01:12 PM
andy escos's Avatar
andy escos
if you are running a after market fuel reg there is always a spare port to screw the electronic sender into
or you could get a 1/8npt welded to the original fuel rail ,if you buy a electronic fuel pressure gauge you should get the boss with the kit .
or get one off ebay
http://www.ebay.co.uk/itm/NPT-1-8-Fe...item4842dd1d79
Old Nov 20, 2011 | 01:20 PM
COLEYST200's Avatar
COLEYST200
my set up
JK12
33
Apr 26, 2021 12:09 PM
StephTell
Sep 2, 2015 06:31 PM
mint_s2
Sep 2, 2015 08:58 AM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
