cosworth engine parts
Here is what i have left from my cosworth,
205 block complete with crank .25, new bearings, high pressure oil pump, block has the usual little cracks between the water ways in some places but didnt affect the running at all, 3 mahle pistons with new rings, the 4th one will need changing but hasnt caused any damage to the bore, block was decked etc when i built it,
Head is a 2wd in very good order, not sure on thickness but i had it skimmed and pressure tested before i built it up, new seals through out,
2wd painted black inlet with throttle body and tps, iscv etc, new bolts and cometic gaskets.
2wd exhaust manifold complete with no cracks etc
open to offers on these bits as im unsuire on what there worth
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
