Sierra Cossie 3Dr Advice please
Old Nov 19, 2011 | 08:55 AM
nomadrouse's Avatar
nomadrouse
Default Sierra Cossie 3Dr Advice please
Hi, Could anyone tell me how you drain the rear diff. on a Sierra Cossie? Cant find a drain plug anywhere! Also on a Sapphire 4x4 Cossie there is a switch under the spare wheel, what is that all about? Is there any clutch cable adjustment on the 3Dr, it has a new cable but too much play and cant find an adjuster underneath, gearbox end. Also does the Sapph. have a cable drive to the speedo or is it electronic (1991) Grateful for any help. Ta
Old Nov 19, 2011 | 09:07 AM
flannigan's Avatar
flannigan
drain the diff oil by removing the cover
the switch on the saff is a fuel pump cutout switch in the event of a accident is shuts the pump off
the clutch ajustment is done by a rachet and pawl system fitted to the clutch pedal and is automatic
and yes a 1991 saph has a cable speedo
Old Nov 21, 2011 | 08:27 PM
nomadrouse's Avatar
nomadrouse
Default Cossie info.
Cheers Flan, I suppose that means a fresh diff gasket? Cant seem to find
the gearbox end of the speedo cable by looking underneath, any tips welcome.
Thanks for the help bud.
Old Nov 21, 2011 | 08:46 PM
robrs2's Avatar
robrs2
No gasket on the diff. You just use a small amount of gasket seal
3dr cossie
11
Dec 21, 2015 03:38 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
knight19770
Aug 4, 2015 12:36 PM
