Ive bought a MK1 FRS! - Turbo advice
Old Nov 16, 2011 | 10:42 PM
dazparki's Avatar
dazparki
Default Ive bought a MK1 FRS! - Turbo advice
Hi guys! What do I need to check to keep the turbo in good condition. Not got a clue how they work or how to look after them. First petrol turbo I've had
Any advice greatly appreciated.
Dazz
Old Nov 16, 2011 | 10:48 PM
Rsmat's Avatar
Rsmat
Im on my second and i think there a great car...just keep it well serviced i change oil and filter every 4k on mine....always make sure the car is up to temp before engaging turbo mode...and allways allow for it to tick over for 20seconds before turning off.
Old Nov 16, 2011 | 10:55 PM
dazparki's Avatar
dazparki
Ah ok. I'd heard about the start up and cool down.
..... So turbos have oil lol. Really don't have a clue! Ok... So is it easy to do yourself or should I just take it to Ford?
Old Nov 16, 2011 | 11:01 PM
Robs Frst's Avatar
Robs Frst
Top advice
Old Nov 16, 2011 | 11:02 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Mat's pretty much covered it TBH.
The oil change which is mentioned is a standard oil change mate, the car will supply the turbo with oil by itself providing everything is in order and working as it should be.
Cheers,
Grant
Old Nov 16, 2011 | 11:09 PM
Rsmat's Avatar
Rsmat
depends how decent you are with the spanners mate...I did mine the other day with my 35% discount at ford and it it cost me Ł28 for everything inc genuine ford oil...took me around 30-40mins to do and is easy compared to most cars.
Old Nov 16, 2011 | 11:28 PM
dazparki's Avatar
dazparki
Ah ok. That makes sense. So have the oil changed, prob every 6 months for me. It's only got 36k miles so I wanna keep it as good as it is now!
Old Nov 16, 2011 | 11:32 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
oil change is easy pal, easy to look after turbo engines, i'm running a well powered zetec turbo setup in my xr2, loads can be done to make them pull much better.
i reckon on 350bhp about now and loads to come as soon as i can sort a clutch to hold the torque.
if you get stuck with servicing etc. then i'm only in blackburn close to J5 off the M65.
Wilsfoci
15
Mar 30, 2016 10:26 PM
cossie_chris
39
Aug 31, 2015 11:58 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
ray barker
Aug 7, 2015 09:00 AM
