General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I need some suggestions on what engine for my 1.3 escort, I'd prefer a fairly simple conversion as it will be my first engine swap. I'm not after mega power, just something a bit more pokey! I was thinking something like an xr3 lump?
mk3/4/5 escort? 3/4 go with a 1.6 cvh as there easy to fit and get hold of, good for 90bhp and feel plenty quick after the 1.3/ or go zetec but you will need alot more for the conversion, what you will need depends on if you stay injection or carb the zetec
It is, without a doubt, worth a bit more hassle to chuck a Zetec in there rather than another 'period' engine IMO... far better and far more reliable option. There are quite a few threads on this on here already too.
Oh ar, forgot to mention It's a Mk4.
I guess It's worth the extra hassle of the zetec, what power do the 1.8's run? And do the 130 spec bits bolt on/in?
Thanks for the replies!
Ben.
early zetec 1.8 are 105 or 130 later ones are all 115, yes all 130 bit bolt onto the othe 1.8's, you will want injuection tank ,rs/xr fuel pump, return fuel lines, efi fuel filter, efi filter to inlet fuel hose, wiring loom and ecu and transponder and key if later zetec, top water hose from zetec with fan switch, hybrid of bottom zetec and cvh bottom water hose, you can either mod a cvh engine mount or or just use 2 bolts on the cvh mount
if you wanted to run a carb on the zetec though just stick the zetec in, use your edis and coilpack loom and get a dnf pinto carb for it, you will need a facet pump and regulator though but wont nee the injection bit or loom and ecu, you can get carb manifolds off ebay cheap enough
mind you the rs2000 i4 conversion is pretty much the same as the zetec too
