sapphire cossie rocker cover oil leak
hi all gunna post a problem for the old mans sapphire cossie, he has suffered with this leak since day one of owning it it leaks oil around seal he has replaced gasket and cover and still leaks done it several times but still leaks only slow trickle not major and could live with it but the question is why ? anyone else have the problem ?
I never use sealant on the cam cover gasket only a small touch on the half moon seals.
What you should do is smear the gasket with grease and torque the cover down using a torque wrench to the settings in the manual and it won't leak unless the cover is warped.
If you tighten by hand it will always leak.
Don't use sealer on the rocker cover, f*cking annoying bodge job
Take the rocker cover off, clean both faces of the head and cam cover of any old sealer or gasket, buy a proper Cometic gasket and new Ford half moon seals. Only bit of sealer you should use is a blob on each corner of the half moon seals to keep in place as you fit the rocker cover.
Mine doesn't leak, so get it sorted
JoeyBoyden
Aug 18, 2015 10:52 PM
st220kyle
16
Aug 14, 2015 06:13 AM
