escort rs turbo ecu's?
Old Nov 12, 2011 | 07:49 PM
yogurtey's Avatar
yogurtey
Default escort rs turbo ecu's?
Just brought my self a g reg series 2, now iv been told its got the wrong ecu on it. i was told it should have and ecu with hearts and diamonds on it, mine has the coloured squares on it. i was told that that ecu is from a series 1 is this right and will it make a difference?
Old Nov 12, 2011 | 08:06 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
blue red blue is a common s1 ecu, it wont matter either way what you have, i found a box with 15 rs ecu's in the yesterday,
some peopl3 say a series 1 is best ecu as it allowed 1psi more and had no knock sensor, i may be wrong but i think you have to disconnect the knock also otherwise it was im permenent knock/safe mode
i could be talking crap its been a very very long time sice i used kejetronic stuff
Old Nov 12, 2011 | 08:13 PM
yogurtey's Avatar
yogurtey
i always thought they were all the same but, 2day i was told that my car wont run right with that ecu on ?
Old Nov 12, 2011 | 08:29 PM
1.9 xr2 on 40's
st170 breaking
as i say^^
they are not identical
Old Nov 12, 2011 | 09:06 PM
orionmojo's Avatar
orionmojo
I was also told the S1 ecu was better for above reasons. they also have a higher rev limit i believe. An S2 will run on any Ecu, but an S1 will only run on an S1 ecu.
Old Nov 12, 2011 | 09:14 PM
phil_rs's Avatar
phil_rs
yam yammer
How's it goin Rob? From the factory it should have a hearts and diamonds ecu. They will run slightly more boost than the earlier coloured ecus. I think most are interchangeable tbh, just check your base idle and ignition timing.
Old Nov 12, 2011 | 09:52 PM
Rick's Avatar
Rick
Later ECU's need a knock sensor, or will run like a bag of shit. S1 or V early S2 is the best as no knock sensor, the knock sensor circuit very often removed timing for fun.
Old Nov 12, 2011 | 10:34 PM
orionmojo's Avatar
orionmojo
I dont really know enough about it to be honest, just what i was told when i had mine set up. my engine is a late MFI (has CPS hole in block) and that runs on an S1 ECU with knock sensor disconnected.
Old Nov 13, 2011 | 07:37 AM
yogurtey's Avatar
yogurtey
So then if my knock sensor it pluged in unplug it, get her set up and it should b beter.
Old Nov 13, 2011 | 07:38 AM
yogurtey's Avatar
yogurtey
Nice 1 peeps
Old Dec 31, 2011 | 08:08 PM
yogurtey's Avatar
yogurtey
after pissin around for ages with no joy trying 2 get my car running better im back to the ecu, mine is a blue, red, black. Which is for series 2s with a knock sensor (late 89s and early 90s) from what ive found out on here. but my knock sensor is not pluged in. could this be the problem? Thanks Rob.
Old Jan 1, 2012 | 03:56 PM
yogurtey's Avatar
yogurtey
nope tryd it today lol
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
