t4 turbo advice needed
what is the maximum power that can be achieved from one of these as im looking to get the most out of my engine and i love my t4 but i am hoping to start racing next year and i want it to be at its best ? any advice greatly appreciated
is that on pump fuel or race fuel mate as i intend on using shell v power to keep costs down Ł3.33 a litre for race fuel is a little outta my budget !!!
the engine is a turbosystems spec jobbie he suggested what parts to use and what compression ratio ect, i got all the machine work and head porting done by/through him he also supplied my tubo wich is a touring car spec t4 the only doubtful part is the inlet plenum wich is a eeciv item and im not sure if that is up to the job when he live mapped it for me he advised to maybe use a heart power plenum cover or better still a propper 500 one and im unsure if my cams will be good enough bd 14,s ?
as dave said depending on spec anywhere from 520-550 hp flat out. There are stories of the old touring cars doing 600+ but I don't think that even if all else was perfect the t4 could physically flow enough air.
Steve
cheers mate i called him today and had a chat he has now convinced me that i should get a sequential box heart plenum and one of his funky inlet cams lol bye bye tremec hello elite
Are you even allowed to run a sequential box in the series you plan to enter ?
I've got a modified version of the EEC 4 inlet using a extra 4 injectors mounted the same as the rs500 ones and according to the guy that had the engine done by HT there is nothing between mine and the 500 inlet on a engine specced like yours, well apart from the cost ofcourse lol
The original owner of mine who raced it back in 1993 said you would get 2 qualifying laps to a turbo on full power ( a claimed 565hp) just shows how things have moved on !
Yeah sequential will be fine it will just put me in class a against the guy I bought my shell off and rod birley to run in class b i would have to use a std t5 casing and there is not a decent gearkit avalable for those imo my tko puts me in class a anyway but weighs a ton and shifting is slow
, I am defianatly going to get a hart plenum I have heard nothing but good about them and it can only help
big_Rad
Sep 15, 2017 09:36 AM
