Do new idle control valves need setting up?
Old Nov 10, 2011 | 07:32 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Default Do new idle control valves need setting up?
Have bought a new ISCV from ebay, have had a quick look at the new one and does the little nut at the end need tightening up or anything?
Or is it "fit and forget"
Old Nov 10, 2011 | 07:36 PM
Rsmat's Avatar
Rsmat
Which nut you on about steve has the one im thinking is the one in the middle in the thin stick.
Old Nov 10, 2011 | 07:57 PM
Steve the Plumber
Mat,
Its the tiny small nut (6mm ish) at the very bottom of the ISCV that sits in the TB,
Old Nov 10, 2011 | 08:10 PM
martysmartie's Avatar
martysmartie
No fit and forget, they are not adjustable, at least it's not supposted to be!
Martin
Old Nov 10, 2011 | 08:15 PM
Steve the Plumber
Thanks marty.
Old Nov 10, 2011 | 08:16 PM
STeve's Avatar
Super Moderator
OE ones are normally dont adjust but aftermarket ones have the screw which acts like a idling screw in case your revs are high or low
Old Nov 10, 2011 | 08:17 PM
Rsmat's Avatar
Rsmat
Originally Posted by Steve the Plumber
Mat,
Ahh marty beat me to it..just fit and forget.
Sheepdisease
Aug 30, 2015 09:11 PM
Steve Escos
Aug 24, 2015 07:56 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Red_bull
Aug 9, 2015 08:34 AM
