need fast answer about a ecu for escort gti
Old Nov 9, 2011 | 05:59 PM
tigz22's Avatar
tigz22
Default need fast answer about a ecu for escort gti
i have a jest ecu on my gti and it may b fkd so iv found a si ecu that is jest also will it b ok to fit this in mine
Old Nov 11, 2011 | 09:16 AM
forevaford's Avatar
forevaford
id say no because its imobilised to the key, also id say your current ecu is ok.
Old Nov 11, 2011 | 12:11 PM
martysmartie's Avatar
martysmartie
Also yours is 1.8, SI may be 1.6?
Also as said the immobiliser won't disarm, unless you have external PATS.
Martin
Old Nov 11, 2011 | 06:50 PM
tigz22's Avatar
tigz22
iv got the key barrel n the bit that goes round the barrel also its off si 1.8 the ecu is a jest like my gti ecu.. im hopeing that this will sort out my problems whitch iv had since i took the car to a garrage 2 yrs ago to have the revs lowerd from 1500rpm at iddle even tho the car ran sweet.. but since i picked it up its had loadsa proibs n the garage wudnt sort it out n said there not goin g to do anything else to it n to take it else where lol.. he said he had repaired the wire to iddle valve plus i kno he had done somit to ecu but dnt kno wat and he said he replaced the breather valve near the coilpack? but since this iv had a hunting and misfire prob with major misfire underload stalling thn not being abble to restart plus the tps is reading as to high voltage at4.5 volts constant.... iv replaced lambda sensor/maf/iddle valve/crank sensor plugs/leads/coilpack etc with no hint of the prob being sorted 1 bloke said its the rings but my car hasnt eaten any oil? but iv been told it cud b the ecu where its been mucked about with? so hopfuly this will sort it out but if not im changing the loom?
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
