New maniverter new problems
Old Nov 9, 2011 | 07:59 AM
anthany's Avatar
anthany
Exclamation New maniverter new problems
Hello all,
Ive just registered as my girlfriends car keeps having a fit and breaking, so I keep having the fun of fixing it.
I have just swapped out the maniverter for a new approved one and now have a few issues.
Engine management light - should I remove the lambda sensors and clean them? or is it just because the cat needs breaking in?
She says it sounds different, is this to be expected? the maniverters were not of the same pattern so would that make the car sound different?
anything else I should look out for?
any help would be appreciated?
regards
anthany
Old Nov 9, 2011 | 08:37 AM
oldford's Avatar
oldford
Cat's do NOT need breaking in. It's more the opposite - if the original problem that damaged the previous cat still exists, this one will be damaged very shortly too.
Get the fault codes read ASAP and post them.
What vehicle are we talking about? Make, model, year, engine, etc.
Did you use original parts or aftermarket ones?
Old Nov 9, 2011 | 08:45 AM
RichieST's Avatar
RichieST
Never heard it called a maniverter before! Try disconnecting the battery for 10 minutes, that will clear the fault codes from the ecu and put the light out. If the light comes back on then get the fault code read and go from there.
Old Nov 9, 2011 | 08:46 AM
anthany's Avatar
anthany
the original problem was the flange connecting to the flexi part of the exhaust rusting to pieces and coming apart.
Its a ford fiesta flight 1.3 early 2002 endura engine.
There were no warning lights previous to the swap. I was careful with the sensors and swapping them to make sure they were not knocked or dropped etc
It was an aftermarket part, comes with a 3 year guarantee. Gaskets were replaced as were the bolts.
Old Nov 9, 2011 | 08:48 AM
anthany's Avatar
anthany
Did not know that about the battery and fault codes, nice tip and worth a go.
Me neither till I tried ordering the stupid thing.
Old Nov 9, 2011 | 09:13 AM
oldford's Avatar
oldford
If there were no warning lights before the repair, my guess is that the ecu thinks the catalyst is not working.
Or you forgot to connect something. A code read will confirm or deny that.
When did the light go on? Immediately after the repair? Or did it come on after a several hundred miles?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
