NO GO
Just had my ERST CVH engine running today for a while, it ran fine apart from a bit of a missfire so i stopped the engine and took the plugs out to clean them, just with a wire brush and a cloth as you usualy do, put them back in (Firind order is right btw) and it just wouldnt start or even fire!, fuel is ok as ive had the plugs out and they are wet and there is a good spark, any ideas anyone? CheeRS in advance. pete
But it hasnt gone anywhere lol, i started it and it ran fine as i said then 15 mins later after cleaning plugs it wont go, sounds like there is compression as its turning over normal and not fast, no mayo at all
Gonna say the same as Andy with the plugs and leads...
I have cleaned em before and not niticed I have slightly bent or moved the tip and thats fooked up the gap, and also taken the lead(s) off and one has fooked inside...
New leads and new plugs - change from £20 if you know the right place to go, and even if it don't solve the issue, at least you have eliminated it.....
This is why I am glad I don't own cars anymore tho
Sorry
Sorry
