Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Powder coating
Old Nov 8, 2011 | 10:43 PM
langer's Avatar
langer
Default Powder coating
Hi guys I've just went and bought powder coating equipment including powder coater, oven, powder etc as iam wanting to give this ago but I've never done it before just watched a couple of videos on YouTube. Has anyone else done this before or does this at work for instance. Iam looking for any tips or help to do this. Iam just needing a sandblaster now incase there's things that need blasting.
Old Nov 8, 2011 | 10:47 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Getting the parts properly clean first is definately the key from what I have seen, like painting its all in the prep.
Old Nov 9, 2011 | 09:46 PM
turbodod's Avatar
turbodod
hi mate am a powder coater in glenrothes just get stuff cleaned right get all old paint off by blastin heat parts up before powderin as it helps powder to take to the parts ur doin i will put up a few pics of parts i have done tomorrow
Old Nov 9, 2011 | 10:52 PM
langer's Avatar
langer
Default powder coating
Hi mate thats perfect, much appreciated. do parts need primered/laquared or does the powder do it all? (looks simple on youtube but just know it wont be) Iam also looking for a decent sand blaster if you no of any kicking about. ive just got my oven up and running today just need to work out the settings etc. Where abouts supplies the powder itsellf is there anywhere local? Sorry for bombarding you with questions it always the same when somethings new iam just wanting to get it rite lol
Old Nov 9, 2011 | 10:56 PM
cossie.con's Avatar
cossie.con
On e issue that I am aware of with this process is that wheels for instance dont need to get too warm as they WILL crack.I know of two separate people whohave had theres done and both didnt last long before cracking. I can tell you that the company in question paid one chap out all though are still continuing to offer the service.Just becareful
Mik
Old Nov 9, 2011 | 11:03 PM
langer's Avatar
langer
will do cheers. ill be practising on my own wheels first lol. although thats mainly what its intended for myself and a couple of mates whilest we potter on with our cars
Old Nov 11, 2011 | 06:54 PM
turbodod's Avatar
turbodod
Default powder
hi mate here some pics of stuff i have powdered and stuff i have had done if i couldnt do them at work
wheels
rocker covers
other stuff
Old Nov 11, 2011 | 07:39 PM
langer's Avatar
langer
Have you got an oven etc at home as well as doing at your work? They look good like. What do you use to mask bits off like on the turbo housing or to put in holes etc I thought foil for squashing in ends etc but wasn't sure
Old Nov 11, 2011 | 08:10 PM
turbodod's Avatar
turbodod
all the stuff i have done is after work hours or go to a mates that has his own place i wish i had a oven u get heat proof tape and u can buy rubber plugs for holes
Old Nov 11, 2011 | 10:01 PM
timbo_69's Avatar
timbo_69
how much have you bought your oven for. as these seem to be very expensive on ebay
Old Nov 13, 2011 | 10:45 PM
langer's Avatar
langer
How come the comment has been removed of here off a guy offering me PDF files with everything I need to know about powder coating?
Old Dec 17, 2011 | 09:41 PM
Paul500+'s Avatar
Paul500+
full time powder coater by trade
Old Dec 17, 2011 | 11:04 PM
langer's Avatar
langer
Tried powder coating a wheel the other day not sure what or if I did anything wrong. I got my oven unto temp (180 deg) set a wheel up, earthed it, dropped my pressure down tp 25/30 psi and proceeded to powder coat. pressing my pedal whilst spraying/dusting the powder on seemed to look even and ok, so I thought.. When I put the wheel in the oven the temp dropped to 165 or summit quite quick so left it in for 15 mins instead of 10 don't know if i did rite or what. On removing the wheel there's a couple of runs (which I didn't think would happen) and quite a few dry bits which looks like not enough powder was on. Any advice kindly accepted. Thanks
Old Dec 18, 2011 | 05:09 PM
Paul500+'s Avatar
Paul500+
needs to be metel temp not even temp would recommend wheels to be left heating up for a good 30 mins at oven temp,cooking the powder off is 10 to 20 mins depending on powder should state coocking off time on packageing. dont try to put loads of powder on cos it dosent make the finish any different, some powders are base coat and need laquer as a top coat some are a high gloss one coat finish
if you need any help giz a shout
few pics of some work ive done
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
S3an
Sep 26, 2015 11:39 PM
Matt Baxter
Sep 16, 2015 07:19 PM
