Not a ford question but I know some lads on here have VW's
Old Nov 7, 2011 | 03:21 PM
cossie.con's Avatar
cossie.con
Unhappy Not a ford question but I know some lads on here have VW's
Just took the rocker cover off off my 2000 Bora(1.9 PD engine) to get to the bottom of a really bad knocking noise(I thought the cam was worn) only to find that one of the rocker shaft bolts is loose.Anyone heard of this before?
Old Nov 7, 2011 | 03:24 PM
boothy's Avatar
boothy
no but i have now
Old Nov 7, 2011 | 03:52 PM
DAN P's Avatar
DAN P
As above mine still sounds sweet at 194k
Old Nov 7, 2011 | 04:09 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
did tightening it fix the noise?
Old Nov 7, 2011 | 04:15 PM
RONNIE AMIS's Avatar
RONNIE AMIS
I work at a vw garage and never had that before. You sure no works been done on it before?
Old Nov 7, 2011 | 04:34 PM
cossie.con's Avatar
cossie.con
The engine was reuilt at 76000 miles as some numpty timed it up incorrectly, however the car has now done 12000 miles so cannot see that being the issue
Old Nov 7, 2011 | 04:36 PM
cossie.con's Avatar
cossie.con
Smile
Am waiting on a friend coming with a spline socket as I dont have one.
Will update when I have done it
Old Nov 8, 2011 | 08:47 AM
the mk1 kid's Avatar
the mk1 kid
No, but hopefully tightening it will resolve the issue - bet you're pleased it's not the dreaded case of chocolate cam!
Tom
Old Nov 8, 2011 | 11:10 AM
gouch1's Avatar
gouch1
sounds like bad workmanship to me
Old Nov 8, 2011 | 11:25 AM
nathansRS's Avatar
nathansRS
c++
It's been over 2 years since I changed a PD cam but I'm sure that is a stretch bolt..
Not quite the same as yours but you may find this interesting:
http://www.honestjohn.co.uk/forum/po...ex.htm?t=92524
Good luck with it anyways, let us know how it works out
Old Nov 9, 2011 | 04:01 PM
cossie.con's Avatar
cossie.con
Unhappy
Examined further and the rocker shaft has snapped in two.(I know there in two halves) WhatI mean is one of the halves has broken into two.Will get a pic as soon as the camera is charged.Broken a bolt at one end and the other end was loose.Now the search goes on for the bolt head
Old Nov 9, 2011 | 04:03 PM
cossie.con's Avatar
cossie.con
Talking
Cheers for that.
Old Nov 9, 2011 | 07:18 PM
nathansRS's Avatar
nathansRS
c++
Sorry to hear that dude. Might be worth taking the cam out while you are there to ensure all the shells and lifters are ok. They should be black hardened lifters if they were replaced with OE parts when the rebuild was done. Don't forget to mark the position of the injector nuts.
Good luck
Old Nov 11, 2013 | 10:21 PM
cossie.con's Avatar
cossie.con
Default Holy thread revival bat man
Still to this day after tightening its fine and now 137k
mk22door
49
Mar 26, 2022 07:15 AM
borboyous
Aug 22, 2015 11:17 AM
pegaz
Aug 12, 2015 07:30 AM
