maf sensor?
Old Nov 6, 2011 | 04:39 PM
actionfighter's Avatar
actionfighter
Default maf sensor?
Ive recently changed the fucked turbo on my mondeo-130 tdci,but found that although the new turbo works it does not kick in till 3500 revs, today i put back on the vacuum from my old turbo which seems to rectified that but its still way down on what it used to be -I just disconnected the MAF sensor and it drove the excact same without it-would it be safe to say that is my current problem?
any thoughts would be greatly appreciated
Old Nov 6, 2011 | 08:15 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
clear the fault codes caused from running it with things unplugged and try that, i bet its much better
and if the turbo had failed then clean the MAF and boost temp+pressure sensors and all hoses as chances are theres a clamp slightly loose or something too.
Sean.
Old Nov 6, 2011 | 08:30 PM
actionfighter
Cheers sean will try that hopefully its something stupid cause im not spending one more penny on it!! Thanks for the help
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
