How to bleed sixpots
Old Nov 5, 2011 | 02:45 PM
Mark_1's Avatar
Mark_1
Default How to bleed sixpots
On my calippers there are two bleed screws, one on each side.
I recon you should start with the calipper the farthest away from the master cylinder, but do you start with the inner or outer bleed screw?
Old Nov 5, 2011 | 03:34 PM
RichieST's Avatar
RichieST
I would bleed outer side first, then remove any remaining air from inner side.
Chas
Oct 5, 2015 07:13 PM
kevin36
Sep 9, 2015 11:12 AM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
