Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
FS:Focus Mk1/Mk1.5 Modified Parts LOADS!
Old Nov 4, 2011 | 11:31 PM
B1G-J0E's Avatar
B1G-J0E
Slow and Low
Default FS:Focus Mk1/Mk1.5 Modified Parts LOADS!
Focus RS seats and door cards done around 53k miles, few marks but very good condition £700
Focus Collection front bumper, black got a long mark on it but good condition no cracks (with mesh and fogs) £200
Focus Collection rear bumper, white few marks but good condition no cracks (with mesh) £200
Focus Collection side skirts BRAND NEW still in the packet with fitting kit straight from ford in primer £200
Focus RS spoiler BRAND NEW in packet with fitting kit in primer £100
Focus ST170 front 300mm brakes with hubs, callipers, calliper carries, EBC grooved and dimpled disc, EBC pads and brake lines. Done 500 miles £300
Focus 16inch ESP alloys (rare) good condition all straight no buckles and some kurb marks
1 Tyre) Capitol Sport UHP 205/50/16 91VXL 5.5mm Across
2 Tyre) Capitol Sport UHP 205/50/16 91VXL 4.5mm Across
3 Tyre) Capitol Sport UHP 205/50/16 91VXL 6mm Across
4 Tyre) Champiro 50 GT 205/50/16 87V 7mm Across £250
Focus 2.0 16v blacktop with 80k miles T752JLS (petrol)
Everything To Upgrade your 1.4 Focus Or Feista, Escort, Mondeo ETC
Engine Complete (I’ve fitted a brand new cambelt and water pump, uprated thermostat. Also comes with K&N oil filter, spark plugs, gearbox oil, cv boots all NEW in boxs and few other bits)
Gearbox
Gear Linkage
Gear Stick And Unit
All Engine Mounts
Drive Shafts
Rad with all Pipe Work
ECU and Loom
Key
Immobiliser Unit
Transponder Box
Ignition Barrel
£400 (everything you need)
Focus 1.8/2.0 Focus Central Throttle body 65mm RED £SOLD
Focus 2.0 16v Fast Road Clutch years 1998-2005 (BRAND NEW)
Organic clutch driven plate (balanced & anti-judder)
Heavy duty clutch pressure plate (balanced and even-clamp tested)
£100
Focus 1.8/2.0 Stainless Steel Powerflow FULL exhaust system 4-2-1 manifold (heat wrapped with 20 metres of wrap)
De-cat pipe
2 box cat back
£250
Focus 1.4/1.6 Stainless Steel FULL exhaust System 4-1 manifold (had a janspeed flexi welded in at £60)
De-cat
1 box cat back
£SOLD
Focus 2.0 petrol and 1.8 diesel (left up reverse) short shifter £50
Focus 1.4/1.6 Roose Motor Sport BLUE induction hose good condition £60
Focus ST170 air box £50
Focus ST170 REAR fog and reverse lights £30
Focus Smoked REAR lights (one screw point has been repaired) fits FINE £SOLD
Focus USA front TOP grill £40
Focus ST170 leather steering wheel needs a clean £30
Focus Stainless Steel Engine Bling from autospecialists.co.uk
Oval Washer Bottle Lid x2
Cambelt Cover
Fuse Box Cover
Fuel Rail
Slam Panel Covers
Air Flow
Battery Cover
Wing Rail Covers
Engine Mount
Strut Covers
Water Bottle Cover and Screw Cap Lid
Oil cap (screw type)
1.8/2.0 Engine Cover
£150
Focus 1.8 Petrol gearbox done around 10,000 miles it was fully rebuilt Thanet Transmissions on the 02/07/2009 and was fully over hauled with new insides, diff and carrier, clutch and slave at a cost of £617.55 millage was 93,487 and cambelt snapped at 103,000 i have the receipt/invoice for proof. Great condition, perfect working order £200
Focus 1.8/2.0 Klarius Cat Back Exhaust. Basically brand new was replaced on the 19/08/10 and millage was 100,711 at a cost of £91.42 and the cars cambelt went at 103k miles. I have the invoice for proof. Looks great condition and works fine £40
Focus 1.8 Petrol LUK Clutch and Clutch Plate and Slave done around 10,000 miles it was replaced by Thanet Transmissions on the 02/07/2009 when Gearbox was done at a cost of £617.55 millage was 93,487 and cambelt snapped at 103,000 i have the receipt/invoice for proof. Great condition, perfect working order £40
Clarke Strong Arm Engine Crane (oil seal is leaking a bit but works FINE) folds up nice as well
£120
All Parts And Items Are In Margate, Kent. I Can Post Most Things Or Cash On Collection Is Fine. You Can Also Send Your Own Courier. Pictures On Request I Have Loads!
My Email b1g-j0e@hotmail.com Or Mobile 07807042279 Names Joe
Old Nov 14, 2011 | 11:35 AM
B1G-J0E's Avatar
B1G-J0E
Slow and Low
Bumppppp
Old Nov 21, 2011 | 08:32 PM
jghs83's Avatar
jghs83
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
Will this fit the st170?
Old Nov 22, 2011 | 05:40 PM
Kelst170's Avatar
Kelst170
Do you know if anyone has had a go at fitting the seats out of a st into a st170 front and rear?
Old Dec 9, 2011 | 01:16 AM
The 5tig's Avatar
The 5tig
Hi Joe
I need a mk1 focus 1999 passenger side door do you have one and how much if not can you put me in touch with someone who has please I'm in south yorkshire
Old Dec 9, 2011 | 01:33 PM
rsmark86's Avatar
rsmark86
Hello mate interested in the running gear but don't need the gearbox
Just everything to do with engine no transmission needed
Old Jan 1, 2012 | 02:35 PM
robfocus16v's Avatar
robfocus16v
How much for 4-2-1 manifold. lowersprings and windflectors??
Old Jan 11, 2012 | 05:14 AM
cabrst's Avatar
cabrst
mail send about the Rear Spoiler
Old Jan 21, 2012 | 10:49 PM
PsychoSi's Avatar
PsychoSi
Default bits needed
Would you sell the fog lights seperate from the collection bumper? and how much?
cheers, si
dojj
111
Jun 10, 2018 09:09 PM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
cozzy jeff
Sep 12, 2015 04:32 PM
