st200 alarm problem
Old Nov 4, 2011 | 07:50 PM
3dr cossie's Avatar
3dr cossie
Default st200 alarm problem
hi my alarm is playing up on my st200 estate
the doors will only lock with the key in each door, i have to lock the rear doors from the inside. the red LED next to the clock has stopped flashing when the engine is off it stays on and it is staying on all the time, even when the engine is running.
any ideas before it goes the the garage?
cheers Matthew
Old Nov 6, 2011 | 07:37 AM
Autosparky88's Avatar
Autosparky88
hi matthew
what alarm is on the vehicle?
sounds like you have the alarm in valet mode which means it is inactive. if you let me no what alarm you have i can help
cheers tommi
Old Nov 6, 2011 | 11:33 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
If it's the OE alarm, then have a look here...
http://www.mirez.co.uk/AlarmProbs.htm
Old Nov 6, 2011 | 12:42 PM
3dr cossie's Avatar
3dr cossie
yes its the OE one, just found that site above, will take alook tomorrow when i'm off work
cheers Matthew
Old Nov 17, 2011 | 04:25 PM
3dr cossie's Avatar
3dr cossie
turns out its blown a 20A fuse in the fuse box under the dash, and its blowing due to a faulty driver side door central locking unit, put a new one in and everything is fine
cheers Matthew
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
