mondeo diesel 1.8 endura 1998 non starter
Old Nov 4, 2011 | 09:27 AM
TFS's Avatar
TFS
Default mondeo diesel 1.8 endura 1998 non starter
hi
i have an issue with the old smoker...
just changed out the alternator, disconnected ground wire on alternator before i started...change went smoothly no problems, upon reconnection of the battery i tried to start but got some odd symptoms
key position 1, everything on the dash lights up as it should
key position 2, petrol light illuminates as does aftermarket boost guage but they then go STRAIGHT out, glow plug light does not come on at all...stereo does not operate
so it would seem there is no ignition live....i suspect a relay?, where is it?
also...when the key is removed from the ignition the oil light and handbrake light glow dim
any advice please?
Old Nov 8, 2011 | 11:26 PM
bluescortcossie's Avatar
bluescortcossie
it sound like it is back feeding somewhere , check all the wiring around the starter and alternator again and make sure its all correct
have you swapped the alternator for a new one or used ? if used , was it def ok ? try disconnecting the small wire on the alternator and try the ignition then
also was the alternator a like for like ?
Old Apr 23, 2012 | 10:58 AM
zeroveritas's Avatar
zeroveritas
check the fuse panel Fuse Nr. 16, and the engine wire cable before the windscreen
key position 1, and moving that cable, when you hear the clicking, your car is can start
my english is very bad sry.
wowk
Mar 30, 2021 07:49 PM
A.t.p
Oct 23, 2015 07:54 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
