Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
idle problems
Old Nov 3, 2011 | 09:26 PM
chrispie's Avatar
chrispie
Default idle problems
i have a 1.8 zetec focus, when im driving the car it randomly stutters just after changing gear but as i accelerate it clears itself, when stopped it drops below 1000 revs an the engine judders a feels like its going to stall an occasionally does stall, also the spedo stops working for a few mins then starts again. i dont know if this is related, i have been told it might be the maff sensor is there a way of testing this,if any other suggestions i would be grateful
Old Nov 3, 2011 | 10:14 PM
martysmartie's Avatar
martysmartie
Look toward the VSS sensor, this would cause what you describe. Only early models had a MAF, later models have a TMAP, which you can't see as it's integral to the inlet manifold.
I guess you were looking for it to clean it?
Martin
Old Jun 10, 2012 | 12:42 AM
bigbro's Avatar
bigbro
hi i have recently converted my 1.6 cvh engine mk4 orion to a 1.8 fiesta zetec engine using the fiesta ecu and loom wired into my own loom car starts fine but as soon as the engine warms up and you try to drive it it starts splutering and losses power to the point where it hardly moves when you press the accelerator to the point where it tries to cut out help me please
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
