MAP sensor problem on Corsa D 1.2
Old Nov 3, 2011 | 11:46 AM
jimmy/taylor's Avatar
jimmy/taylor
Default MAP sensor problem on Corsa D 1.2
can anybody help me with this one.......
2007 corsa D 1.2 petrol, engine light on.
Plugged in and got fault code PO068-manifold absolute pressure sensor circuit range/performance.
fitted new Map sensor and grommet but has made no difference at all!
The code comes back as soon as the engine is started.
The MAP voltage seems fixed at 4.82 volts and pressure at 101kPa
This does not alter with the engine running or stopped or the sensor plugged in or unplugged.
Ive checked the wiring which looks okay and checked all fuses which are all good.
Any ideas anyone??
Old Nov 4, 2011 | 12:20 PM
jimmy/taylor
Anybody?
Old Nov 4, 2011 | 01:17 PM
creator's Avatar
creator
Was it a new vauxhall sensor used?
Also check for a short circuit between terminal 22 on engine ecu and terminal 3 on map sensor
Old Feb 2, 2012 | 11:55 AM
jimmy/taylor
turned out to be a new sensor which was faulty!!!
swapped for a different one and all is good
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
