fault code on astra dti 0831
does anyone know what this code is
car is loosing power then the eml come's on and it drives normal, on motorway driving its fine but sometime's has a misfire it also smoke's sometime's
had diagnostic check and code 0831 come's up i can seem to find out what it is
thanks for your reply lads ive sorted it
i forgot to say egr vavle had been changed code for egr valve is 1405
if anyone come's across this code 0831 its the clutch pedal switch ive disconnected it and its fine, im going to order a new one so it keeps the eml off
merlin have you got a data disc i bought one once of ebay it give's you loads of codes for all makes and tels you where the socket is to connect it but it got damaged and ive not been able to get another
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Si B
Sep 12, 2015 06:49 AM
