new turbos announcement - GTX2860R, GTX2863R, & GTX2867R.
Old Nov 3, 2011 | 07:58 AM
Yura's Avatar
Yura
Default new turbos announcement - GTX2860R, GTX2863R, & GTX2867R.
Seems like GTX2867R turbo map similar with GT3071 but will has better responce. And I think GTX2860R map will be similar with T34.63 but with much better responce.
Garrett® GTX Turbochargers will be available in several new sizes including GTX2860R, GTX2863R, GTX2867R, GTX3576R:
Old Nov 3, 2011 | 09:00 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Been waiting for that to happen, seemed like technology that would scale down.
Should be great for people wanting to make big power out of a small engine that they can take such big pressure ratios.
Not sure I'd ever want a 1 litre engine with 3 bar of boost down its neck personally, would just use a bigger engine instead but Im sure the bikers will be over the moon!
Old Nov 3, 2011 | 02:18 PM
wilky's Avatar
wilky
any turbine wheels size inducer exducer size
Old Nov 3, 2011 | 02:30 PM
Chip's Avatar
Chip
Not up on their site yet.
Old Nov 3, 2011 | 03:23 PM
TimC's Avatar
TimC
Chip from those graphs, How much do you think the presure ratio will corespond with boost presure? Is it likely that 2 on the graph scale will still be equal to 1bar atmospheric?
Old Nov 3, 2011 | 03:47 PM
Chip's Avatar
Chip
Pressure ratio means its based on whatever pressure you have at the inlet side of the turbo, with a decent inlet filter and in a low country like england thats going to be very close to atmospheric yes mate.
So the 2 there is essentially 1 bar of boost, and the 4 is 3 bar of boost.
Old Nov 3, 2011 | 05:56 PM
TimC's Avatar
TimC
Looks like I might need to buy a new Map sensor and get the Omex recaliberated.
Iv been umming and ahing whether to go for a GT3071 with a .82 hot side or some sort of GT28 for ages. Looking for a reliable 300 on moderate boost and would like to push 400 but with the best response I can get, so if these GTX28s do as the comp map says I think I havefound my perfect turbo. For a C20LET may I add.
Old Nov 4, 2011 | 08:20 AM
Yura's Avatar
Yura
the same sizes as GT28.
By the way GTX2867 will be available with T3 internal gated flange and seems like it will produce about 450-470hp like old t38.
Old Nov 4, 2011 | 08:31 AM
stu21t's Avatar
stu21t
Thatbwould b great in a road car, 450bhp but spooling like std!
Old Nov 4, 2011 | 08:52 AM
Chip's Avatar
Chip
Assuming they follow the same pattern as with the GTX30, you'll even be able to use an existing GT28 housing.
Old Nov 4, 2011 | 08:58 AM
TimC's Avatar
TimC
Im hoping I can utilise a T3 external gate flange since that what my manifold is
Old Nov 4, 2011 | 09:35 AM
Yura's Avatar
Yura
correct
Old Nov 4, 2011 | 09:55 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Did someone say 3bar! Where do i buy one. MAD boost junkies only need apply
Old Nov 4, 2011 | 10:46 AM
TimC's Avatar
TimC
You not selling up now Rich?
Old Nov 4, 2011 | 01:35 PM
wilky's Avatar
wilky
i have one here but cant deside on the turbine size the 60mm gt30 or the smaller 56mm[i think its 56mm ]i have a gt30 60mm t28 exhaust housing here ,if the newer ones use a smaller turbine wheel then i will have to fine a different turbine housing may be a gt28rs and have the wheel nocked out to a bigger size
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
